Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-16-2007, 10:36 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Thumbs up 99+ Grand Am - Replacing fuel filter
First you'll need to relieve the fuel pressure.
Either from the schrader valve under the hood(on V6 models) the 4 cyl does not have this schrader valve .
You can also pull the fuel pump fuse # 48 under the hood fuse box.
Start the car and allow it to run untill it dies,
which will releave most of the fuel pressure.
Once that's done,
you'll still need some old rags to catch any fuel the will drain from the line fittings when the fuel filter is disconnected. Watch your eyes!!!
You'll need a wrench for one end,
and the other is clipped in with a plastic retainer clip.
They sell a tool just for this disconnect but is not usually necessary.
This is how the nipple end is connected/held in place.
The Filter is located in the rear of the car,
just above the rear axle shown below.
Here are some pics with instructions....
Be carefull when inserting the nipple end shown above.
If you jamb it in at an angle you can damage the "O" ring that is inside the fuel line fitting,
and is very difficult to replace if at all.
If you need any firther assistance ,
PM me or post your thread in the Grand am or N body problem diagnosis forum(s) and someone will help you asap.
Good Luck
1999 Grand Am SS 3.4 OHV
Old 01-15-2008, 07:16 PM
Re: 99+ Grand Am - Replacing fuel filter
Here is another pic(with directions)
it might help out with disconnecting the fuel line(s).
The Following User Says Thank You to xeroinfinity For This Useful Post:
autowill (01-25-2014)
Closed Thread
