| N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance. |
dsm injectors?
ok, i know they will go on with a little modification... but a friend that "knows hondas" and has worked on them for years said that a first gen dsm injector will not only fit, but plug right up witout doing the resistiors or the box... is this true? or does it still have to have the 10ohm resistors?
95 Civic EX H&R sport springs KYB AGX Struts Energy Suspension Poly Bushings 15" black VSR's on nitto NT450 not-so extreme performance 205/50/15 CAI http://www.cardomain.com/ride/2489240/1 |
Re: dsm injectors?
you might have to drill out the o-rings a little to get them to fit, but that's not a big deal. If you have an OBD1 car, the injectors will clip in, but if you're OBD2, then you have to get a resistor pack and a set of injector clips from an OBD1 Honda
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
Re: dsm injectors?
so obd 1 hondas can use 1st gen dsm blue top injectors without any mods?? then what is the whole dead end plug and the resistors? only for obd2?
Re: dsm injectors?
For OBD1 and OBD2 cars you're going to have to drill out the Orings to get the DSM injectors to seat properly. The difference is that OBD2 cars need a resistor pack in order to run OBD1 injectors (i can't remember but i think those are Peak and Hold, while OBD2 injectors are saturated)
Here is a diagram of how to hook up the resistor pack in a standard Honda application heres a diagram for the install ![]() heres how it looks. hope this all helps.....any questions, let me know
Re: dsm injectors?
concerning acuras and civics, both obd1 and obd2 systems run on saturated injectors. obd1 and obd0 injector clips are the same. unless your wiring is already made to run peak and hold injectors, you will need the resistor box or some inline resistors.
http://www.automotiveforums.com/vbul...d.php?t=558151
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
Re: dsm injectors?
i have an extra resistor box for sale if you're interested.......
