Old 05-06-2006, 12:32 AM
graphicassult's Avatar
graphicassult graphicassult is offline
Send a message via AIM to graphicassult Send a message via Yahoo to graphicassult
Oil leak question
So i had a valve cover leak and fixed it but then switched to Synthetic too soon and now the leak is back, is there anyway to fix an oil leak while running synthetic oil?
"All right Ramblers, let's get ramblin."
Old 05-06-2006, 01:19 AM
jessep28's Avatar
jessep28 jessep28 is offline
Re: Oil leak question
What milage, year, type (SE, GT, GTP) of Grand Prix do you own?
Did you isolate the old leak? Are you sure this is the same problem recurring?
00' Pontiac Grand Prix GT
83,500 mi
Old 05-06-2006, 10:02 AM
grandprix dude749 grandprix dude749 is offline
Is your car yound and low mileage? Cause if you just swapped over to Synthetic at 100000km's your not helping that engine.Its recommended straight from the manufacturers that you son't go over 40000km if you want to run Synthetic.
Domestic and sexy
Old 05-06-2006, 11:06 AM
1999 Grand Prix GT, leak is isolated, i know exactly whats going on. I was just wondering how to swtich out gaskets since your supposed to condition them when you switch to sythetic.
If anything i'll get liquid RTV gasket and put it on there, just hope i dont need in it...
Old 05-06-2006, 11:12 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Are your operating conditions so harsh that you need synthetic or is it just personal preference?
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 05-06-2006, 11:21 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
your car has rubber valve cover gaskets, and the RTV will turn them to snot and ruin them. The switch to synthetic will cause leaks on old seals and such because it flows thinner than conventional, but it shouldn't affect a recently replaced gasket or seal.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-06-2006, 12:06 PM
KX2000GTP KX2000GTP is offline
Should anything be used to seal the gaskets? or no?
Old 05-06-2006, 01:31 PM
richtazz's Avatar
no, put them in dry.
Old 05-06-2006, 07:36 PM
Well its the exact same leak as i had and had the gasket replaced. About 2 weeks later i switched to full sythetic. I did it for personal pref. because it will still work better than conventional. I'll look but i'm 99% sure its from the same spot...
Old 05-06-2006, 09:40 PM
wlkjr's Avatar
I"ve used conventional Havoline for 306,000 miles. I don't know how it could work any better.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
