Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-27-2006, 06:21 AM
Preacher35's Avatar
Preacher35 Preacher35 is offline
light bar wiring question
Just one question: Is there an accepted, standard way of routing the wiring harness for a roof-mounted lightbar, into the vehicle? I would really prefer to not drill any holes through the painted sheet metal. Suggestions? And, OFFROADX, just an FYI: I did search the forum prior to asking the question! hehe.
Thanks
Old 01-27-2006, 09:03 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: light bar wiring question
I don't have lights on the roof, but I do have cables for my rooftop FRS antenna and CB, I just shut them in the rear doors and zip-tie them to the center roof rack post.
I also have a thin wire for my outside temp sensor probe that runs from under the dash, out the driver's door near the hinge, up under the weatherstrip to the cowl, then under the rubber at the edge of the windshield to the roof. It runs over the sheet metal for a couple of inches before going into the rain channel under the front roof rack base. If your wires aren't that thick, that could be an option.
Brent
When did you last check your spare tire's pressure?
Old 01-28-2006, 08:24 AM
Svendog Svendog is offline
I did the same thing.. I run the powered wired through the firewall, out near the front passenger door hinge, along the windshield's weatherstripping and over a couple inches of sheetmetal, zip tying it to the rack. On the other side, I run the combined ground wire to driver's side, down the windshield weatherstripping, through the gap in the driver's side door hinge and back into the engine compartment, grounding it to the frame. It took a little time to do this, but it keeps a clean look and limits the exposed wires to just a small area - which I may cover somehow to protect them from possible damage.
Old 01-29-2006, 01:28 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Under the weatherstip. If you lay the wires flat you can run 4 side by side easy. Over the sheetmetal and then zip tied between the cargo-basket and the rack tubing.
Xterra4x4.com and the Xterra Offroad Webring
Old 01-29-2006, 02:53 PM
Preacher35's Avatar
Thanks Schlud and everyone else that replied! Gonna get on it this weekend!
