Old 06-20-2005, 04:55 PM
jemch72 jemch72 is offline
Thumbs up Any tips changing spark plugs?
Hi, all we know that is hard to change the spark plugs, I already toke a good look around and i am planning to do it...any one have any tip to share and make it easy or any tip to avoid a night mare?
I normally take care of my astro since I discover oil leak in the filter after oil change in a well know biz, so , I do it my self..but never befor change the spark plugs, and time and mile are calling it...1996 at 137,000 miles..
Thanks
Old 06-20-2005, 08:42 PM
CD Smalley CD Smalley is offline
Re: Any tips changing spark plugs?
Do whatever it takes. I have gone through the fender wells, done some from underneath the van and some from inside with the doghouse off....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 07-13-2005, 02:26 PM
astro44 astro44 is offline
I have a '94. When I changed those I was able to do the right side (passenger) from inside the van. On the left side I was able to reach up from underneath the van and did it without having to use any extensions. You won't be able to see what you are doing only by feeling your way around. A good tip I learned when you put the new plugs in cut yourself a 4 or 5 inch piece of high temp hose that fits snug over the end of the plug. This makes the plug easier to handle and help you get it threaded in the engine block. It works awesome. patience... good luck
Old 07-13-2005, 07:33 PM
Hi, I just did the passanger side, I did the brakes and without the tire I was able to reach the 3 at that side, the other side look like more hard to do..let see what happend tomorrow when I finish....
Thanks for the hose tip!!
Old 07-15-2005, 09:14 AM
james wright james wright is offline
Pull wheels go through fender wells need long ext. on some short on others worst one #8 but still easer than through dog house
Old 07-31-2005, 10:48 PM
Hunter82 Hunter82 is offline
you could use the end of a old plug wire to help thread new plugs.
Old 08-10-2005, 12:54 AM
Aqua Angel's Avatar
Aqua Angel Aqua Angel is offline
Send a message via ICQ to Aqua Angel Send a message via AIM to Aqua Angel Send a message via MSN to Aqua Angel Send a message via Yahoo to Aqua Angel
Re: Re: Any tips changing spark plugs?
or be like me, a skinny young French Bitch. hire a 110 lbs kido to slid his hands to get those plugs. that is what i am. lol most people hates me for this.
i am able to work in a cramped position, but for those of you? hummmmm hard to say, ask your kids to do it for you.:P
93, Chevy Astro van, Saphire Blue, Led tail light.
looking for:
Euro clear corner lights and Billet grill "chrome" and a good shinny 5 spoke rims and a disc brake rear differential
Old 07-01-2007, 12:24 PM
Roaster Roaster is offline
Thanks
I have read every comment in this forum and I have found a mechanic who will do the Job for $100.00 dollars. It might be very much worth that because it only has to be done every 100,000 miles. He will do the whole service and replace any worn hoses as well. I think that is the I will solve this problem. Thanks for the help.
Old 07-04-2007, 08:08 PM
boatbuster boatbuster is offline
easiest way to replace your spark plugs is to have someone else do it for you!!!
Old 07-08-2007, 07:29 PM
old_master's Avatar
Advisor/Moderator
Please check the date on threads before responding to them. This one is two years old and the original poster probably has replaced them at least once by now.
