Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-07-2005, 09:20 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Talking How many miles do you have your Isuzu?
I thought I would start this trend to watch our members Rodeo's rack up the miles over the years.
Here is the format to use:
Year:
Engine:
Mileage:
Any major problems:
Here is another post with Isuzu owners mileage:
http://www.4x4wire.com/forums/showfl...c=1&PHPSESSID=
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-07-2005, 09:22 PM
Isuzu Guy
Re: How many miles do you have your Isuzu?
2000
3.2 v6
61k [edit] 69k Dec 2005 [edit] 77k Feb 2007
IMG replaced, plugs, tires (68k), rear brake pads (74k), IMG replaced again, s-belt pulley (77K) fliters, fluids, fluids and more fluids!
-Ryan
Isuzu Moderator
Car Show Tips
Old 03-07-2005, 09:32 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
1999
3.2 v6
73,000
IMG, Minor Exhaust work, most fluids, major tune-up, rear wiper motor,
Old 03-07-2005, 09:36 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
1997
3.2L SOHC V6
140k miles
Major Problems.. none.
2000 VW New Beetle TDI
2007 Honda CR-V
The Following User Says Thank You to Canucklehead For This Useful Post:
cherry97rodeo2WD (08-02-2021)
Old 03-07-2005, 09:49 PM
aitch aitch is offline
3.2 v6
164k
never seen the shop!
Will
The Following User Says Thank You to aitch For This Useful Post:
Old 03-08-2005, 07:28 AM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
1998
3.2 V6 4WD
113k
So far so good!!
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
Old 03-08-2005, 09:15 AM
ncfedcop ncfedcop is offline
Mileage Reply
173,312 Miles
1999 Rodeo
3.2 V6
Never been in Shop
Old 03-08-2005, 10:22 AM
Ramblin Fever Ramblin Fever is offline
Year: 1997
Engine: 3.2L V6
Mileage: 135,500
Major problems:
Nothing, Nada, Ziltch!
Below are items that have been replaced outside of fluids, tune-ups:
Timing belt/water pump/tensioner (per maintenance rec. @ 59K)
Tires (1st replacement set @ 69K)
Power steering pump (replaced @ 90K)
Shocks (replaced @ 90K)
Valve cover gaskets (replaced @ 100K) thanks to my laziness in having a shop change my oil and putting in a quart too much.
Tires (2nd set @ 118K)
Battery/Alternator (replaced @ 120K)
No ticks, and no marking territory.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
The Following User Says Thank You to Ramblin Fever For This Useful Post:
Old 03-08-2005, 09:54 PM
90durham 90durham is offline
1993
285,000 Kilometers
3.2L
Only had it 2 months but felt good about buying it with this mileage.
Old 03-08-2005, 11:00 PM
kromone kromone is offline
3.2 V6
A/T
210,000
Timing belt, fuel sending unit, plugs and all the fluids
226000
Intake manifold gaskets and fuel injector seals
242000
Brake pads, front rotors, rear brake shoes.
TPS sensor
rear axle bearings
256000
Repacked front wheel bearings.
Greased shift lever release button mechanism and where the handle and shift lever connect.
Was starting to lock up when shifting in and out of park.
270000
Replaced timing belt.(180000 on belt)
Replaced sparkplugs.
Old 03-09-2005, 01:01 AM
SOLSTER SOLSTER is offline
3.2L V6
60k miles
No Major Problems.. ABS wire harness, I consider that minor problem
basic maitenance only, 5.5 years young, very reliable!
Love my 4x4
all original parts, i.e. starter - battery - timing belt - brakes - etc...
<EDIT - date: Dec 2005>
65K miles and 6.3 years - orginal owner
since last update:
needed a new battery and a new starter. still running great!
<EDIT>
GREAT IDEA DOING THIS POLL RYAN!
1999 Isuzu Rodeo S 3.2L, 4x4, Auto, Great Truck!
2007 Pontiac Solstice GXP, Aggressive Red
Old 03-09-2005, 02:57 PM
rodeo02 rodeo02 is offline
2002
3.2L
32000mi
Never been in for a warranty issue. Replaced one O2 sensor, filters & fluids changouts.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-09-2005, 06:56 PM
RodeoRider99 RodeoRider99 is offline
Send a message via AIM to RodeoRider99
Year: 1999
Engine: 3.2L V6
Mileage: 115,000 and counting
Major Problems: Fuel Sending unit replaced @ 65,000 mi. (I don't consider this major, just the only extraordinary repair)
Old 03-09-2005, 10:30 PM
LuvLizard LuvLizard is offline
1997
3.2 V6
181,899
Replaced water pump, radiator, thermostat, all belts (including timimg belt), and tensioner pulley recently. Replaced shocks last year. Runs great!
Old 03-10-2005, 08:39 AM
Jovian9 Jovian9 is offline
3.2
V6
>60k
Front rotors 3X (in less than a year) d/t warping
front bearings 1X (but repacked 1X after that)
front pads 2X (in less than a year d/t warping)
Intake Gasket
Fuel Sending Unit
Front R Wheel Speed Sensor (front R quarter panel needs replaced d/t a minor accident I had b/c the ABS were too sensitive and went off and I rear ended someone)
Turn Signal Relay
Rear Rotors and Pads (2X)
Serpentine Belt
Idler Pulley (2X in a year)
