Old 02-16-2005, 07:08 PM
ryanb4614 ryanb4614 is offline
Send a message via AIM to ryanb4614
Front end conversion
What is all that i need to buy for a 1997 recessed lights to change them to a composite lights?
Old 02-16-2005, 07:23 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Front end conversion
front grill, wiring harness
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-16-2005, 08:02 PM
wireing harness?,,, do i need a new bracket/ core support??? And do u have any idea where i could get "cutting glaze" i cant find it anywhere
Old 02-16-2005, 08:27 PM
BlazerLT's Avatar
AF -Advisor
you will just need the new grill as I stated in my previous post.
Yes, you will need the composite wiring harness seeing it uses a different bulb setup than the sealed beam units.
Old 02-16-2005, 09:06 PM
i kno i needa a grill, is the wiring harness hard to do? The bracket support or core support do i deff need one of those?
Old 02-16-2005, 09:54 PM
BlazerLT's Avatar
AF -Advisor
I can't really tell you how easy it is.
I have never done it.
Old 02-17-2005, 06:09 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
He will need core support as well. The core supports aren't the same due to the headlight mounting brackets on the composite lights... HE needs the following
Grille
Core Support
Composite light housings with brackets
Filler panel (where grille meets core support)
We just did the conversion with Nater06 Sunday evening. He drove out from Ohio. Took us 3 hours...(front body mount bolts were corroded).
I can most certainly say the core supports are different for the headlights
Old 02-17-2005, 04:01 PM
where can i get all this? checked my local junk yard "called" only had old blazers.. know of any website or someone selling it let me know.
Old 02-17-2005, 04:08 PM
BlazerLT's Avatar
AF -Advisor
Ebay, it has everything you need.
Old 02-17-2005, 04:55 PM
is there any other way i could change the front hide the recessed lights?
Old 02-17-2005, 04:59 PM
rlith's Avatar
www.car-part.com
Old 02-17-2005, 05:46 PM
rlith's Avatar
Re: Re: Front end conversion
Fiberglass the front end solid?....
Old 02-17-2005, 06:06 PM
never heard of that, i might just put in the clear corners, get euro front lights, then get white lights and a push bar/ grill cover.. a black one
Old 02-17-2005, 06:12 PM
rlith's Avatar
Ryan, I was being facetious..... Just go to www.car-part.com to get your parts... Call Wagner's truck and van parts in Harmony Pa. They will have the lights, core supports and grille...(they're a wrecking yard, as of friday they had tons of them because they have so many s10's. blazers, etc... Call 411 for the number. The lights will run you about 75 a piece, the core support about a 100-125, the grille will be about 75-100, Optionally you can call New Castle Autowrecking in New Castle Pa., ask for Adam, it will run you about the same there.
Old 02-17-2005, 06:49 PM
yeah but i cant drive anywhere out of my town yet.
