Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-24-2005, 11:32 AM
arche002 arche002 is offline
96 explorer stuck in 4WD low
I have a 96 Explorer with 180K miles. Somehow it got stuck in 4 WD low and it won't come out. Any suggestions?
Old 01-24-2005, 03:44 PM
saperich saperich is offline
Re: 96 explorer stuck in 4WD low
Try backing up, then going foward
a coupple of times, toggleing the switch.
Old 01-24-2005, 07:48 PM
ixoxoli ixoxoli is offline
Send a message via AIM to ixoxoli
before i knew how to operate 4x4 correctly i had this problem too,
To fix your problme, put on neutral then switch to 4wd low or from 4wd and then you put on Drive, you cant switch to or from 4wd low on anything besides neutral.
if that doesnt fix, reset computer but unplugging battery and connecting it back.
Old 01-25-2005, 09:26 PM
krsc05 krsc05 is offline
i have the same problem you're having. just wondering if you tried unplugging the battery and connecting it back. did it work?
are you still stuck in 4 wd low?
is there any other ways of getting out of 4wd?!?!
this is driving me nuts!!
Old 01-25-2005, 10:52 PM
trucku's Avatar
trucku trucku is offline
I have gotten stuck in 4x4 (2002 xls 4.0)while my vehicle was in Auto mode. I just disconnected the battery for a minute. It worked for me..3 times so far. Your shift motor on your transfer case may be the issue, or maybe your shift module behind the glove. You definately have to be in Nuetral to shift out of 4x4 LOW. Check your fuses. To do a full reset, disconnect batter for 10 minutes. Don't just start vehicle. Turn the key till dash lights allow it to cycle guages and then start it. It worked for me hope it helps you.
Old 02-18-2005, 07:21 AM
crashedu182 crashedu182 is offline
Send a message via Yahoo to crashedu182
take the 4 bold out the shift motor and turn it by hand when you take it off you'll see what i'm talkin bout it says what way to go
