| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
89 Beretta GT rebuild (WIP)
Well, here's the latest with me. My 3-tone Mustang was the last thing I built and well, this is just a re-build of one of my old kits. It's an AMT 1988 Chevrolet Beretta GT model (extinct) and I kinda did some custom work with it when I first built it (T2 wing, window louvers, Blitz front bumper, Civic rear bumper, etc). But now, I made a custom body kit, converting it to RWD and dropping in a Camaro LS1 V8 in it. I have some pics of the kit. These are before sanding, and this is my first time using actual puddy. I hope you like it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Any comments? I know I need to sand and add more putty to the front peices of parts tree I used and I need to re-do my side skirt design a little bit, but what do you guys think overall?
Current model build: 1988 Chevrolet Beretta GT ![]() http://www.automotiveforums.com/vbul...d.php?t=337732 <--Progress |
Re: 89 Beretta GT rebuild (WIP)
Pretty cool model, I never knew it existed. Doesnt look to bad, you said it yourself for what needs done.
1972 Datsun 240z, 45k, l28 1990 Nissan 240sx, 96k ka24eT 1994 Nissan Altima 1997 Nissan 240sx SE |
in the 6th pic down, you can see a little line I made in the putty. I sanded everything above that line so it's no-longer there. It looks much better sanded down, but I do still need to add more putty to the front of the kit. I'll get more pics when I get home from work right now, as being on here is probably going to make me a little late. I just wanted to update everyone (since this thread has been up about a half hour :roll
as promissed, updated pics.
![]() ![]() ![]() sry for the crappy pics, but my space is kinda limited.
keep going keep going!
Plenty of work in front of you. Keep it up and good luck
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
Update. I puttied the window louvers (where the actual thing meets the car) so it looks like it's molded right to the car itself. I also took off the wing and I'm experimenting with a smaller, "touring" type of a wing. If it doesn't quite work out, I'll just put this one back on (It was actually a little crooked anyways so it didn't really look right). As for paint, well....that'll be a little bit of a suprize. I will tell you this. The colors will be blue and black.
ok, Got some pics for ya. I filled in the gaps for the louvers and put on the other smaller more low-profile wing.
![]() ![]() ![]() ![]() ![]() ![]() it's now sanded, cleaned, and ready for primer.
That front bumper looks good, are those Xenon foglites?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes 1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials 2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater |
omg your ricing an american car
/me covers eyes looks good tho, from a modeling view.
Re: Re: 89 Beretta GT rebuild (WIP)
EDIT: the foglights are actually not suppsed to be like that. I origonally painted the car blue, and then later re-coated it in black. the glue ate away the black paint thus showing the blue (I did this model way before I even knew anything about models.
With a LS1 in that thing that wing will be the only thing keeping' you not cleared for take off
Those Beretta don't weigh that much, do they?Lil'budman |
less than a Camaro (If I'm not mistaken)
Looking good. You should level out the side skirt to match the front & rear kits.
~Josh~ OldUser:IImportSupra Do You Have a Car that Goez Sideways?
the Beretta weighs in around 3,000 LBS and the Camaro around 3300. not a huge diifference, but enough.
Looking good so far! |
