Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 09-08-2004, 10:11 PM
Elk's Avatar
Elk Elk is offline
Question limited slip/locking differential
I don't have a Fiero yet, but I was wondering: what are the options?
How much do they cost, what types are available and how hard are they to install?
Do they come stock on some Fieros? If so, which models and what type are they?
Old 09-09-2004, 04:42 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: limited slip/locking differential
All Fiero Transmissions, both manual and automatic, have open differentials. There aren't any off the shelf limited slip units available that I am aware of. There are probably custom manufacturers out there that can make them, one just has to look. (and look, and look, and look)
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 09-09-2004, 09:22 PM
Elk's Avatar
Elk Elk is offline
So far I've found this: http://www.mmrusa.com/phantom1.htm
Shouldn't there be more available since the Fiero shares the same transaxle (Getrag) with a bunch of other FWD cars? Or do Fieros use a different differential?
Would I have to remove the transaxle to get to the differential? Can the gearing be changed? What ratios are available?
Don't all the Fieros that have been modified by adding bigger V-6 and V-8 engines need limited slip differentials, or do they all accelerate slowly while leaving one big skidmark?
Old 09-12-2004, 09:35 AM
FWDs aren't candidates for limited slip, with the driving wheels steering the poor things would need 3 lanes to make a right turn.
You will need to remove the transaxle and split the case to change the differential.
All Fiero getrag final drives are 3.61:1. There is a 3.94:1 final drive that was used in FWD 92-93 Quad Four H.O. cars, and it will bolt right in to the Fiero's 5 speed (getrag that is) but it's no longer available new and hard to find used.
In most drag-only Fiero's, the Differential spider gears are welded solid. Most street cars live with a one wheel wonder.
Wanted to buy:
Old 09-17-2004, 12:52 AM
Blue02R6 Blue02R6 is offline
I found this....
http://www.geocities.com/pontiacjeff/EPlsd1.html
and this...
http://www.mantapart.com/8694ga.html They are way down at the bottom
and this...
http://www.mantapart.com/new.html
Now as far as I know, in order to install a LSD in a transaxle you have to modify the case.
My Stable:
2002 Yamaha YZF-R6
1988 Pontiac Fiero
1969 Pontiac Firebird
I might get my '02 SS back....
Old 09-22-2004, 01:30 AM
DesertChuck DesertChuck is offline
Bud's Outback in Tucson AZ makes a beefier 4 puck version of the Phantom limited slip for all transaxles including automatic.
look in Dexonline for phone.#
as far as I know, no machining.
Chuck
