Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-01-2004, 11:37 PM
Culpeper Culpeper is offline
Noise at 1800-2100 RPMs
wonder if anyone with a 3.0L is having it? My 90 4Runner has 135,000 miles. Engine does not make noise in neutral, but only under load from 1800-2100 rpm, VERY noticable in the cab. It's a vibrating noise that appears to be coming from the dash. I don't think it is the speedometer cable and related parts because the noise is only RPM specific. The vehicle has an automatic transmission. Any ideas on what to look for?
Old 05-02-2004, 08:10 AM
91 funrunner 91 funrunner is offline
Re: Noise at 1800-2100 RPMs
thumping,ticking,can you feel it in the seat or the whole car? need more details ;()
Old 05-02-2004, 10:35 AM
It sounds like a vibrating dash noise during that RPM range. Like something is loose and only vibrates within that RPM range. I can't feel it in the wheel, seats, or accelerator pedal. It's basically just a noise.
Old 05-02-2004, 12:21 PM
Tomsriv Tomsriv is offline
That is a very common rpm range for V engines to resonate. Check your exhaust system mounts, transmission and motor mounts. If they are bad it might transfer more vibrations to the cab.
Old 05-02-2004, 06:17 PM
Okay, thanks! I'll check all that out.
Old 10-11-2004, 05:40 PM
Re: Re: Noise at 1800-2100 RPMs
What about a "phrump phrump" while backing up in reverse. Sounds like normal V6 exhaust noise to me but someone told me it's a rod bearing. I had it at the dealership lately and asked them to diagnose the motor noise and they said they didn't hear anything mechanical noise. BTW, they couldn't trace down the buzzing noise coming from the dash. It sounds like a exhaust heat shield is vibrating and resonating through the dash.
Old 12-20-2004, 07:19 PM
Resolved the noise I was describing;
Using chassis ears pinned down the noise to the left fender well. Insulated/tightened down air filter box, mount point from fender to radiator, alternator wiring harness. The noise was harmonic meaning at a certain rpm range under load it would create a vibration through the left fender well. The noise/vibration would travel this area of the chassis like a bell and reverberate behind the instrument cluster inside the cab. So much so that to the naked ear you could swear the problem was with the dash or instrument cluster area.
Old 12-26-2004, 03:48 PM
Thanks for telling us about the solution culpeper. To often people will not give any feedback on wether or not our opinions are useful. Could you tell the airbox was loose by wiggling it? Maybe next time someone has that problem I can tell them to check for missing bolts or mounts on the underhood parts.
Old 12-26-2004, 04:52 PM
Thanks. No, the airbox appeared to be on tight.
