Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-09-2004, 04:11 PM
koly koly is offline
92 camry front drive axle
I'am changing the front drive axle's and i can't remove the right drive axle. I have removed the snap ring and the locking bolt but i can't pull the complete axle out. Has anyone had the same problem
Old 03-09-2004, 07:27 PM
Erndog1369 Erndog1369 is offline
oh yeah.. you most like are NOT going to get that out. That bearing gets seized in the mount. An air hammer, pry bars, and sometimes some heat are the only way to get that out of there. Are you getting a new axle???? Here's my suggestion..... remover the large CV boot clamp just to the outside of that bearing that you cannot remove. Pull the inner joint apart, and when you get the new axle, do the same thing, and install the new half and replace the clamp. This is the easiest way to do it, and you replace all the wearable parts of the axle still.
Old 03-09-2004, 09:06 PM
fredbros72 fredbros72 is offline
Re: 92 camry front drive axle
right on the money erndog, that bearing does not come out, 1/2 shaft swap best way to go
Old 03-10-2004, 06:27 PM
Re: Re: 92 camry front drive axle
Thanks for the help. I did what you said and it went fairly well
Old 06-22-2005, 09:06 PM
300+ 300+ is offline
I finally had to replace my passenger axle again at 318,000 miles and this time I just swapped from the inner joint out and left the bearing in as mentioned above. So easy this way. Couple hours beats a couple days and no need for the hassle of a shop. Maybe even easier than doing a split boot.
Old 06-23-2005, 09:47 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
If you search this forum, you can find a description of someone's procedure for pulling that inner shaft.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-26-2005, 04:11 PM
mrtwo mrtwo is offline
I want to do the job too since my right side outside boot is leaking. I am wondering how long is it going to take? What special tools i need?
