lowering a 87 stock 87 crx with stock suspension
hey all i wanna know how can u drop a 87 crx with the stock suspension??
Re: lowering a 87 stock 87 crx with stock suspension
cut the springs. or take a torch to them and bend them either way its gunna be wonkey
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~ |
lowering car
what about the front they are only shocks??
arn't there struts in the front? those springs can be cut too. i knew someone who had a first gen civic with the springs cut so far that they were loose when not under load. but going that far is not advisable.
umm my front of my crx are only shocks there are no springs just shocks
Wow...
The front has torsion bars. If you want to lower it you can adjust a nut on each side to lower about an inch. Anymore and you will have to mod the torsion bars. Then the back... You can put springs in from the first gen wagon to get about an inch drop. When you loser the back you will have to install or fabricate an adjustable panhard bar. Best bet: Coil-overs in the back with adjustable panhard bar. Mod the from torsion bars and drop one notch. More at: Redpepperracing.com Read the FAQ’s. Good luck! GL |
were are the nuts located can u send me a pic?
doesn't the first gen wagon have leaf springs in the rear, my second gen wagon does.
hey.. im new here and i want to know....were are the front torsion bar nuts located??? plese e-mail me... [email protected]... thanks for the help....
Re: Re: lowering a 87 stock 87 crx with stock suspension
If you get under the car you will see the torsion springs. They are in a tube about 24" long and about 2" in diameter. At the end furthest from the engine there will be a cap bolted to the side of the subframe. From this cap follow the tube towards the crossmember (towards the engine). Just before you reach the crossmsmber you will find an arm about 4" long attached to the tube (pointed towards the tube on the other side of the car). This arm will have a nut at the end of it. This is the height adjustment nut!! There is one on each spring and if I remember correctly, this is a 17mm nut. Do not confuse this nut with the bolts that hold the crossmember in! Sorry to bring back an old thread! Last edited by lxndr; 06-01-2004 at 04:21 PM. |
thank you. ill try to do it..if any body has any doubts.. just hollar!!!
