Old 07-21-2003, 09:58 PM
michaelsd16c michaelsd16c is offline
jdm cluster
I just got my jdm cluster for my 94civic manual. I took out the stock cluster and I took for four (4) plugs out from the back. When I go to intsall the jdm one I can only put two plugs in which are the mane ones. But what are the other two plugs for? from the stock cluster? One is green and the other yellow.
Old 07-21-2003, 10:13 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Something tells me those are the fuel and temp gauge plugs... Everything should be plug and play though, you sure you got a 5th gen JDM cluster?
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 07-21-2003, 10:22 PM
Yea I got it from autosonic and it said 92-92 jdm cluster(manual) EG-6
Old 07-21-2003, 10:44 PM
HXCivic97 HXCivic97 is offline
Send a message via AIM to HXCivic97
on the 6G they're white and yellow, but i think it's basically the same. He's right though it should be plug and play.
Old 07-21-2003, 11:53 PM
So dose that mean that I got the wrong one? And the SRS light stay on is that normal . I have a 94 civic 2 coupe ex. are the Eg-6 ment to fit in the ex coupe with SRS?
Old 07-22-2003, 12:19 AM
1) The SRS light should stay on for approx 6 secs and then cut off. If it stays on then it's registering a problem (perhaps because some plugs aren't plugged in??)
2) The EG6 i believe was the SiR/SiR II i believe? I don't know how the SiR compares to the EX, but i am pretty sure about what the EG6 is - maybe that'll at least help someone else answer the question =)
Old 07-22-2003, 01:12 AM
Well I put my stock ones on and it works fine, as for the SRS like you said comes on for a couple of seconds and then its off. With the jdm one it just stay on. I looked on the back of the jdm cluster and I see two spots where some plugs could go but their just empty. Like if it was an option to get. My ex cluster light (brake,seatbelt,SRS,and check engine all are full up.If you look at a civic dx cluster your going to see that some are blank becuase it didn't come with that option. SRS or ABS.
And yes their are two plugs that don't get plug in the jdm cluster green and yellow. Do you know if any of the civic in japan came with SRS?
Do you know what the 92-95 SI-R civic EJ-1 is?
Old 07-22-2003, 03:08 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Like everyone already stated, it's plug and play. I have one in my coupe and all I did was unplug the USDM one and plug in the JDM one. If there are any problems then you bought a faulty one.
Old 07-22-2003, 07:44 PM
So you where able to plug all four plugs in your jdm cluster? You have EX with SRS right? The small plugs that wouldn't plugs into my cluster are the green and yellow?
Old 10-17-2003, 10:14 PM
khmerboy khmerboy is offline
I've noticed that the Jdm cluster has the fuel low warning light, is that functional? It sucks that the USDM doesnt have that feature. Is it really worth it the to replace USDM with the JDM cluster? Just wondering that's all.
Old 10-17-2003, 10:41 PM
B16EJ1's Avatar
The light is functional but you have to run your own wiring. The only reason is for the simple fact you have the JDM one. The reason behind me getting on is so I could just know when my JDM B16 is actually at redline. I have a programmed ECU and the rev limiter is at 9100 so instead of watching how far I can ride in the USDM one I just shift when I hit red on the JDM one. No clock sized tach w/ a big, bright ass shift light for me.
Old 10-17-2003, 11:30 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: jdm cluster
..something I wish I could get rid of
There would be big ugly holes in my dash if I took it out, and I have no clue how to fix.
About the cluster, you got the incorrect one. Or, you could always post pics...
Old 10-18-2003, 12:10 AM
B16EJ1's Avatar
It's understandable for a car that has none but if a car already has an OEM tach. It's just not my flavor. I like that OEM shit.
Old 10-18-2003, 10:44 AM
Ricochet's Avatar
Banned
Re: jdm cluster
Me too that's why I want a ctr cluster and get rid of my "clock" lol.. but I don't know how to clean up holes in vinyl on the dash.
Old 10-18-2003, 02:33 PM
Re: Re: jdm cluster
Maybe you could try this? ---> http://www.asseenontv.com/prod-pages....html?afid=281
Dont know if will work but worth a try right? I you do try it let me know if it works out!
Jdm Cluster???climate Control??? vtecrx '88 - '91 Civic | CRX | Wagon | Shuttlee 0 12-03-2003 12:12 AM
jdm cluster question.. 91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 2 10-13-2003 10:07 PM
JDm cluster 2000dollarZCbs '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-11-2003 04:50 PM
jdm cluster EF_LSVtec '88 - '91 Civic | CRX | Wagon | Shuttlee 10 10-11-2002 11:09 AM
JDM cluster in! raring to go! :) 13secondcivic '71-'87 Civic | CRX 8 01-13-2002 06:54 PM
