Go Back   Automotive Forums Car Chat > Buick > Tips and Maintenance Procedures
Tips and Maintenance Procedures Post helpful tips, maintenance guides and R&R procedures for all Buick models here.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-14-2003, 08:46 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
1997 to 1999 Buick Lesabres
Important
Before entering the programming mode, verify possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases. The other transmitters will not be functional until you program the transmitters again. You may program up to 4 transmitters.
Perform the following procedure when adding new transmitters or replacing failed transmitters:
1 Turn the ignition switch OFF.
2 Use a fused jumper wire in order to jumper the DLC terminal 8 (BLK/WHT) to terminal 4 (BLK).
3 Close all of the doors.
4 Turn the ignition switch ON. The doors will cycle to lock.
5 Press and hold the LOCK button and the UNLOCK button on one transmitter. After a 30 second delay the doors will lock and unlock.
Important
Do not turn the ignition OFF or the first transmitter will become inoperative.
6 In order to program extra transmitters, repeat step 5.
Disconnect the fused jumper wire from the DLC.
Attached pic is a pic of the connector.
2000 to 2004 Buick Leasbre
You need a scan tool to program.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
1997 Buick Lesabre randomly Dies (Electric) MikeTwoJay LeSabre 2 04-16-2009 08:37 AM
Programming remote (FOB) for 2004 Toyota Solara JSherry58 Solara 6 09-19-2008 08:08 AM
Programming Remotes from 1996 to 1999 Riviera Flatrater Tips and Maintenance Procedures 0 07-14-2003 09:03 PM
Programming Remotes from 1997 to 2004 Regal Flatrater Tips and Maintenance Procedures 0 07-14-2003 08:57 PM
Programming Remotes from 1997 to 2005 Century Flatrater Tips and Maintenance Procedures 0 07-14-2003 08:23 PM
Closed Thread
