Old 11-23-2013, 05:32 AM   #1
JeremyJon
JeremyJon's Avatar
Alternate Flocking Technique Tutorial
Carpet flocking can be challenging for some, here is an alternate technique, and one which I use
Enjoy!
JeremyJon is offline   Reply With Quote
The Following 3 Users Say Thank You to JeremyJon For This Useful Post:
blubaja (11-23-2013), lovegt40 (11-29-2013), Tompidom (11-30-2013)
Old 11-23-2013, 06:56 AM   #2
Mr Plumb
Mr Plumb's Avatar
Re: Alternate Flocking Technique Tutorial
Excellent stuff! I'm currently building a Suzuki Samurai and the only thing stopping me completing the build is the flocking! Can't seem to get it right yet with other cars I can do the flocking no problem!
Will give this a go for sure many thanks!
ELP Modelling - YouTube
Mr Plumb is offline   Reply With Quote
The Following User Says Thank You to Mr Plumb For This Useful Post:
JeremyJon (11-29-2013)
Old 11-24-2013, 12:21 PM   #3
ChristopheB
ChristopheB's Avatar
Interesting, I will give it a try.
Christophe.
ChristopheB is offline   Reply With Quote
The Following User Says Thank You to ChristopheB For This Useful Post:
Old 11-28-2013, 09:59 AM   #4
F1-Fan
Interesting technique, thanks for sharing it.
F1-fan
F1-Fan is offline   Reply With Quote
The Following User Says Thank You to F1-Fan For This Useful Post:
Old 11-28-2013, 10:53 PM   #5
rsxse240
I can see using this for floor mats and dash pads, trunk liners and underhood insulation. thanks for the tip!
The Following User Says Thank You to rsxse240 For This Useful Post:
Old 11-28-2013, 11:54 PM   #6
360spider
360spider's Avatar
Nice technique. You can also get some fuzzy paper at most craft stores for this. They sell it in various colors and its very thin and easy to apply.
ItalianHorses.net
360spider is offline   Reply With Quote
Old 11-29-2013, 07:21 AM   #7
JeremyJon
JeremyJon's Avatar
Yes, works very well for those items too, floor mats cut out are easily adhered to the base carpet, with just a couple dots of glue to underside
For under engine hood lining, I like to use layered masking tape, it has a smoother surface & more realistic of production car material, yet has a slight grain to it still, and not fuzzy as the flocking/carpet would be
Use multiple layers, to build up thickness, then you can cut out to shape directly on (unpainted) hood, other cut-out details then are easily added, to simulate any other patterns or shapes or steps like production liner might have
It then can be painted flat or satin black, and CA glued along edges to secure in place & you're set
Old 11-29-2013, 07:24 AM   #8
JeremyJon
JeremyJon's Avatar
There is, here the crafts stores is not as commonly carried
Some felts and velor fabric materials work well too, depending on scale
Old 11-30-2013, 12:40 PM   #9
corvettekid_7684
Do you do anything to keep it from rolling up when working with it?
corvettekid_7684 is offline   Reply With Quote
Old 12-01-2013, 03:12 AM   #10
JeremyJon
JeremyJon's Avatar
From the tape rolling up? I never have had it do that, but when I lay down the upside down strips (before flocking applied), I just use a transverse piece of tape on each end to hold them flat while flocking and cutting
The nice thing about masking tape, is that once the flocking applied, it will bend, and shape to corners or ridges
Old 12-15-2013, 02:11 PM   #11
jzx100
jzx100's Avatar
Great technique. I like the fact that it will take the shape of the surface that is beneath it. Nice
jzx100 is offline   Reply With Quote
The Following User Says Thank You to jzx100 For This Useful Post:
JeremyJon (12-15-2013)
Old 12-18-2013, 10:02 AM   #12
kcirick
Would this work on Seats? They have much more complex shapes and curves...
I also need some texture on the steering wheels, any ideas for this?
Thanks,
kcirick is offline   Reply With Quote
Old 12-18-2013, 03:05 PM   #13
JeremyJon
JeremyJon's Avatar
Thanks,
Wouldn't work so much for seats nor a steering wheel, but also the grain of the flocking would look more extreme on either of those
A more traditional method for a grainy surface on those, is to spray on paint lightly from a further distance than usual, and only in light amount (not a covering coat), to form a stippled effect, it works quite well especially in flat colours
