Old 06-11-2013, 10:15 AM   #1
denilsonvm
denilsonvm's Avatar
Porsche 917LH Hippie
My new project... the Porsche 917LH "Hippie" that raced Le Mans in 1970.
Box contents
All pieces prepared and primer applied
Body painted with a mixture of X-4 and X-16 from Tamiya
References
Regards,
Denilson
denilsonvm is offline   Reply With Quote
Old 06-11-2013, 02:40 PM   #2
ianc911
Re: Porsche 917LH Hippie
Looks Great!
Question: what primer did you use?
I tried building this car recently and just could not get the paint (using same mixture of Tamiya X4 & X16 as you) to lay flat. It was always orange-peeley and pebbly no matter what pressure\thinner ratio I used. Finally I just gave it up after stripping it twice and it's sitting in a box right now.
I had used Krylon white primer on it, but now I'm wondering if my troubles weren't related to that. I've since switched back to using the Tamiya primer, but just curious what you used here?
Thanks,
ianc
ianc911 is offline   Reply With Quote
Old 06-11-2013, 03:37 PM   #3
denilsonvm
denilsonvm's Avatar
Originally Posted by ianc911 View Post
Looks Great!
Thanks,
ianc
Hello ianc,
I'm not at home right now, so I can't check, but I think it is PPG Microfill Primer 1500. Never had a problem with it. A friend just warned me that the color should be more purple, will try to fix that.
Regards,
Denilson
Old 06-12-2013, 07:13 AM   #4
denilsonvm
denilsonvm's Avatar
Repainted with a mixture that has more purple
Old 06-12-2013, 03:42 PM   #5
ianc911
Yes, I like that color better; the first was too blue. Will be looking forward to seeing the rest of this build. Perhaps you'll inspire me to take mine out of the box again!
ianc
Old 06-13-2013, 03:12 AM   #6
zippernl
New color is far better then the old one. Keep it going!
zippernl is offline   Reply With Quote
Old 06-13-2013, 10:46 PM   #7
denilsonvm
denilsonvm's Avatar
Just start placing decals
Old 06-14-2013, 12:16 PM   #8
ianc911
Nice work! Glad to see you didn't have any trouble with the decals; I was dreading that...
ianc
Old 06-14-2013, 10:48 PM   #9
MidMazar
MidMazar's Avatar
Stand out porsche and i'm sure it will be a stand out build.
In Progress
Old 06-15-2013, 09:12 AM   #10
denilsonvm
denilsonvm's Avatar
Thank you guys!
Big decals on place...
Old 06-16-2013, 12:16 AM   #11
JeremyJon
JeremyJon's Avatar
Looking good D, that darker purple is definitely better! bravo!
JeremyJon is offline   Reply With Quote
Old 06-16-2013, 04:48 PM   #12
123yokomo
123yokomo's Avatar
one of my favs nice job so far!
123yokomo is offline   Reply With Quote
Old 06-16-2013, 11:04 PM   #13
denilsonvm
denilsonvm's Avatar
Thank you guys!
All decals placed. First layer of clear coat applied.
Old 06-17-2013, 06:58 PM   #14
sprite46cfk
You did a great job with those decals! My Fisher 917 is in limbo with decal issues. The original Fisher decals were very stiff and would not lay down for anything. Tried the Colorado version but they had fit issues since I believe they were designed for a slot body. Anyway, good work!
Chuck
sprite46cfk is offline   Reply With Quote
Old 07-01-2013, 04:58 PM   #15
denilsonvm
denilsonvm's Avatar
Hello Chuck, my Fisher decals cracked when I put it on water. I used Colorado decals, but I had to cut then in several places to fit correctly.
Interior finished.
Denilson
