| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
1989 Cutlass Ciera runs Sluggish / righ/ hesitant
OK i have a 1989 cutlass ciera sedan , has 65000 miles on it (orignal)
2.8 L. V6 It drove great with no problems to what im fixing to explain , i did a oil change / filter , changed spark plugs and changed the pcv valve after i did those 3 changes it runs ok in park, but when i drive it shakes, runs sluggish and is hesitant to give me the power to go, Im guessing i moved something around and the car did not like. I put all the orignal spark plugs and pcv valve back on in case that would fix it which did not, I checked all the orders of the spark plugs wires they are correct, I went replaced the spark plug wires and still does not fix the problem.. Im guesing it could be a mass air flow sensor ? but again I did not touch jack except what is near the pcv valve which was located in back of the engine on the manifold ( was not a good place to put it) ideas please Thanks |
Re: 1989 Cutlass Ciera runs Sluggish / righ/ hesitant
Did you gap your plugs correctly?
yep gap '45 and i took them out to check and make sure they were gapped right and check for cracks
