Go Back   Automotive Forums .com Car Chat > Toyota > IS200/IS300/IS350/Altezza
Old 11-23-2004, 01:10 PM   #16
TRD2000
TRD2000's Avatar
Re: altezza wiring diagram (3S-GE Beams)
just alloy.... hmmm should bolt up.. hope the oil and water ports align.
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
TRD2000 is offline   Reply With Quote
Old 02-14-2005, 07:26 PM   #17
chengkhang
Send a message via AIM to chengkhang Send a message via MSN to chengkhang Send a message via Yahoo to chengkhang
i finally got some pictures, some bad pictures,........... but there pictures.......
http://photobucket.com/albums/v468/c...mr2%20project/
wait before you say any thing,...
that is the black top altezza,... look a little closer,.........
i used the intake manifold from the red top, among other parts.... i manage to get,... i was lucky enough to come across a fellow from aus.......
but there it is
it fits,..........
alittle tight on the right side but ill do something about that later,......
but most important
"im still looking for wiring diagram!"
chengkhang is offline   Reply With Quote
Old 02-14-2005, 07:44 PM   #18
TRD2000
TRD2000's Avatar
If I Find The Diagram I'll Let You Know...
I Thought The Right Side Would Be Tite, It Looks Like Only The Exhasut Port Timing Actuator Is In Place, Does The Vvt Work On The Inlet As Well??the Inlet Gear Doesn't Have The Big Actuator Thing Off The End...
So How Hard Was It To Get In Again? Looks Pretty Cramped!
haha and yeah was a bit confused with the red top manifold on there, but i saw the valve cover ina later pic...
Old 02-14-2005, 08:00 PM   #19
chengkhang
Re: Re: altezza wiring diagram (3S-GE Beams)
thatll be great,.... it is pretty tight....... but if i cut off that little frame thingy on the wheel well than i think it should be eoungh room,... hopefully,...
ohhh there both in, its just that the exhaust side has a bigger one,.....
umm well droping the motor was as easy as droping a the regular motor in,........ so if you if you have taken out mr2 motor as much as me in one summer,.... its pretty damn easy just time consuming,.....
i also used the altezza throtle,.... i had to make a spacer to connect the throtle to that intake manifold,.........
and i also used the old pan from the redtop......
and some modifying with the timing tensioner,..... weeeww that was a hassle,..... finding the right bearing wheel,....
and other things,...
Old 05-07-2005, 10:30 PM   #20
ke203sge
Question I'm also looking for Altezza loom/wiring diagram
Maybe some of us shall "group buy" the translation from toysport?
I've started up my own RS200 front cut, but i need wiring for the oxygen lambda sensor into the loom. *help*
Additionally i need to know how-to make a working speedo (need the left-front abs-sensor(ref: Bill Sherwood i think)). RPM signal is also taken from the ECU, right?
Aaaaand, i need to connect radiator+temp gauge, oil pressure sensor+oil gauge in dash +++
After all those things are done i feel like rip out unnessesary(?) wires under the hood and dash/coupe. It weighs like two shitloads.
Carina_rwd: i think i've visited your page once. U have several Carina TA12's? One of them has nice grey metallic?
EDIT: Carina_rwd and other rwd'ers. What did you do to solve enginebottom hitting the crossmember and steering? I have the same trouble as Bill Sherwood, but i have a KE20 med r/c ball steering. I've tried a SW20 MR2 suspension, waiting for MA60 Supra mk2 parts. I'm trying to get this street legal, and want to use OEM Toyota parts. But yes, i do have considered using Volvo 240/760 parts due to availability.
*help*
ke203sge is offline   Reply With Quote
Old 09-29-2005, 09:29 PM   #21
Julian Khor
Re: I'm also looking for Altezza loom/wiring diagram
Hi all,
I'm new to this forum.
I'm driving a RS200 beams dual vvti 5 speed auto transmission
I'm looking for the Altezza RS200 RPM wiring diagram which is from the ECU.
Has anyone got the diagram for the RPM line from the ECU?
i'm trying to install the remote start to my car.
Thanks in advance
cheerz
Julian Khor is offline   Reply With Quote
Old 12-13-2010, 06:21 AM   #22
jay_russell
any chance you have the gauge diagram for the rs200 z 2005 edition. after it for a custom job
jay_russell is offline   Reply With Quote
