Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-01-2014, 05:12 PM   #1
comet240
00 ram 1500 trying to remove pitman arm from gear box
ok I must be doing something wrong I have busted 2 pitman arm pullers
what I did was unloosened the nut and washer from the gearbox and then I attached the puller to pull it away from the gear box. even tried heat
what am I doing wrong since there is no instructions in the hayes book
comet240 is offline   Reply With Quote
Old 08-19-2014, 08:25 AM   #2
Stale Trooper
Stale Trooper's Avatar
Re: 00 ram 1500 trying to remove pitman arm from gear box
Try using a little penetrating oil on the gearbox shank (the splined joint) above the pitman arm, let the oil soak in for a few minutes, loosen the nut, but don't remove it, then put the pitman arm puller on it and add tension until it is very snug, but not so tight that it bending, wait a few minutes, to give the penetrant time to do it's work, then give the arm a few whacks from the sides to break it loose from the shaft. Check for index marks or mark your shaft & arm to assure re-installation will be correct. Remove the nut now, then lower the steering parts.
Patience and lubrication will make this job a lot easier to finish.
A good home-made penetrating oil is a 50/50 mix of acetone & ATF. once you mix this up, keep it capped tightly when not in use to prevent evaporation
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
Last edited by Stale Trooper; 08-19-2014 at 08:33 AM. Reason: added more information
Stale Trooper is offline   Reply With Quote
Old 08-19-2014, 09:08 AM   #3
comet240
ah ok well I got it off I used the cutting torch to heat up the pitman arm for a few minutes couldn't get penetrating oil to work and then I put the pitman arm puller on and it came off but using just a propane torch didn't work wasn't hot enough. guess it was really on there ,, and then I just used anti seaze on the splins. Found out I didn't need to buy a rebuild kit, as the mechanics don't even repair them. The mechanic said u can do the repair with the gear box in the unit.
You take the C clip off and while the truck is running you turn the wheels and the pressure blows out all the seals and then you hammer up new ones without having to remove the box. as they don't bother replacing the internals go figure lol
and I guess you cap your home made penetrating oil as it would evaporate the acetone. right
and how well does that stuff work
Old 08-20-2014, 10:27 PM   #4
Stale Trooper
Yep and how well does that stuff work
It was tested against WD-40, Marvel Mystery Oil, and several other Penetrants the highest torque was like 450 Ft/Lbs versus 50 ft/lbs for this mixture.
Stale Trooper
'05 CVPI
Old 08-20-2014, 10:29 PM   #5
comet240
ok when you mean compared to this mixture for foot pounds you mean the acetone /trans mission fluid is only good for bolts tigthend down to 50 foot pounds
and wd40 is good up to 450 foot pounds so hen its worth buying it then making it?
Old 08-20-2014, 10:36 PM   #6
Stale Trooper
No, after applying the Acetone/ ATF mixture, it only took 50 ft/lbs to break loose the chemically rusted bolt & nut. With WD-40 and the other penetrants being tested, the torque was as much as 450 ft/lbs to accomplish the same task as the 50 ft/lbs that the mixture used. Get it now?
Stale Trooper
'05 CVPI
Old 08-20-2014, 10:38 PM   #7
comet240
oh ok gotcha
so how long does it take for it to soak though
as I know the acetone evaps fast too, I guess it things out tranny fluid
was told before too use tranny fluid on bolts it helps
Old 08-20-2014, 10:44 PM   #8
Stale Trooper
Not long
Stale Trooper
'05 CVPI
Old 08-20-2014, 10:45 PM   #9
comet240
ok ill have to try that then I got both just need to get a spray bottle
Old 08-21-2014, 06:28 AM   #10
Stale Trooper
Here are references (in other Forums) to the ATF/Acetone mixture: http://www.jalopyjournal.com/forum/t...owdown.350800/
http://forums.sohc4.net/index.php?topic=20131.0
(See bottom of page 1, for another mixture called "Ed's Red")
Another concoction is brake fluid & ATF
One can also Google ATF & Acetone to find more links for additional information.
Stale Trooper
'05 CVPI
