Go Back   Automotive Forums .com Car Chat > Automotive Art > Car Modeling > WIP - Motorbikes
Old 06-05-2013, 07:30 PM   #31
evilduse
evilduse's Avatar
Re: Yamaha YZF750 Tech 21 Fujimi
That's one reason why I like these forums. I learn how to make better (hopefully) models and learn something new every time I get on. You guys are all more informed about the subject matter than I am!
evilduse is offline   Reply With Quote
Old 11-10-2013, 08:30 AM   #32
andrew59it
After a while some progresses
Painted and masked the fairing using the decals as a template
First layer of clear (2k)
andrew59it is offline   Reply With Quote
Old 11-10-2013, 08:32 AM   #33
andrew59it
The exhaust takes 2 days of work but I'm satisfied with result.... there are some gaps but they will be hidden when the bike will be closed
Old 11-10-2013, 10:49 AM   #34
generationx
generationx's Avatar
Excellent finish and weathering!
generationx is offline   Reply With Quote
Old 11-11-2013, 07:42 AM   #35
andrew59it
I have made a little modification to the exhaust support cutting an angle of the hole. In this way I may place them after closing the 2 half of the exhaust.
Now the radiator
and a whole sight
I have made the connection on the oil tank with T2M details. The Holins decal is too large and it need to be cutted
Old 11-11-2013, 07:45 AM   #36
andrew59it
Installed the exhaust support and made the connection between the oil tank and the rear shock
Old 11-11-2013, 10:24 AM   #37
John18d
nice progress Andrea - really looks the part
The shock reservoir came out nicely and your exhaust hanger bracket looks good
what material did you use for the exhaust hanger bracket?
Thanks
John
John18d is offline   Reply With Quote
Old 11-11-2013, 10:58 AM   #38
andrew59it
Hello John if you mean the bracket of the springs they are Top Studio p.e.
Old 11-11-2013, 11:09 AM   #39
John18d
Andrea - I mean the one that goes from the frame to the exhaust can
John
Old 11-11-2013, 11:15 AM   #40
andrew59it
It's a kit part.....
Old 11-11-2013, 02:14 PM   #41
John18d
Oh I understand - you just modified the end where it attached to the exhaust can.
I miss-understood and thought you made the whole piece.
looks really good though
John
Old 11-11-2013, 02:28 PM   #42
John18d
Andrea - the sprockets and chain look really good too
did you airbrush them or did you paint with a brush?
also what color gold did you use for the chain?
This YZR is really coming out nicely
I can only hope mine will be close to what you are able to do
I learn so much every time you or Sandro build a bike
John
Old 11-11-2013, 04:18 PM   #43
andrew59it
Hello John
sprockets and chain are airbrushed.... I used the tamya enamel gold for the outside and gun metal for the center section.
Some weathering did the rest....
Old 11-12-2013, 08:54 PM   #44
ricrosar
Looking great, excellent work.
Rick
ricrosar is offline   Reply With Quote
Old 11-18-2013, 03:20 AM   #45
andrew59it
Just a litlle modification to the headlight....
made a hole and glued a lens from Wave with uv glue....
Better than nothing.....
