| Latest | 0 Rplys |
10-17-2009, 01:23 PM | #1 | |
fuel shutoff emergancy? 02 liberty?
does the 02 have some sort of fuel shutoff
our liberty wont start after a fender bender here there is no fuel pressure and the fuel pump does not turn on after fender bender Last edited by bratt; 10-17-2009 at 02:25 PM. |
10-17-2009, 01:59 PM | #2 | |
Re: fuel shutoff emergancy? 02 liberty?
Nope. What fender?
10-17-2009, 02:24 PM | #3 | |
smashed the bumper off and hood bent, motor looks fine but wont start
When the key it turned the starter turns the motor I checked for fuel pressure and there is none. the pump is not being turned on. I guess it was shutoff by a crash sensor is the check engine light supposed to come on for a moment when you put Key on? Last edited by bratt; 10-17-2009 at 03:39 PM. |
10-17-2009, 08:59 PM | #4 | |
The fuel pump has a fuse and a relay. The relay gets energized by the auto shutdown relay. If parts are missing than a close look for broken connectors/wiring would be a good start. I had a neon the other week that you really couldn't see any front end damage but things where pushed around enough to break off one of the bulk connectors to the PCM.
10-17-2009, 09:05 PM | #5 | |
hi Airjer,
so where are these relays? under the hood? which relay are they? what position / row is it at? there is no fuel pressure when I try to start, I know something has disabled the fuel pump |
10-17-2009, 09:23 PM | #6 | |
Have an owners manual?
There should a power distribution center under the hood.
10-17-2009, 10:18 PM | #7 | |
yes, i see the relay fuse box
but I dont know which relay is which I think they all work. The wiring is all there and has not been cut none of the relays are broken |
10-17-2009, 10:44 PM | #8 | |
Aren't they labeled on the inside of the cover?
You might want to bring it in and have it diagnosed.
10-18-2009, 06:34 PM | #9 | |
Look for a push button reset they hide them along side fenders behind a brace. If you push the reset button it should start if you had a minor fender bender.
The location is always located in the owners manual. You can look in a Chilton's or Haynes manual. |
10-18-2009, 08:45 PM | #10 | ||
If it where a ford you would eventually find one somewhere. Chrysler/Jeep you can look all you want, You won't find one. In fact I think ford is the only manufacturer that uses a resettable fuel cut off switch.
10-19-2009, 08:52 AM | #11 | |
I did search and the 2006 and 2007 Jeep Liberty web site lists an emergency fuel shut on the Jeep web site. I also found a Jeep technician who said you need a DRB3 scan tool to access this devise. I assume the latest OTC Genius scan tool would do this. A lot of independent shops use these. Some shops use Snap On scanners.
