Go Back   Automotive Forums .com Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 12-13-2011, 02:09 PM   #1
erik874296
What would I need to repair?
I recently got into a collision with a concrete barrier as my car skid in the rain. I recently got a brand new engine/transmission from a dealership in it that is still untouched from any damage so I've decided to keep the car and fix it up. The car still works, sounds normal, no apparent leaking fluids. I was wondering what all I would obviously need repaired on this car. I have already bought new airbags for it.
erik874296 is offline   Reply With Quote
Old 01-04-2012, 02:35 AM   #2
Moppie
Master Connector
Moppie's Avatar
Re: What would I need to repair?
If it hit hard enough to set the airbag off you will likely need more than just bolt on repairs.
Do you know a mechanic or panel beater who can put it up in the air can check the chassis rails etc?
Moppie is offline   Reply With Quote
Old 01-04-2012, 06:46 AM   #3
LearnAutoBody
Auto Body Mod
LearnAutoBody's Avatar
I agree, you need to have a shop look at it to determine if there is frame damage, suspension damage, you will need a front end alignment, you will need someone to install the airbags and clear the codes. It looks like there may be damage to the lower radiator support, which is a weld-on part. The radiator looks like it will need to be replaced. Probably the a/c condenser, fan... I would have a shop look at it and have them perform the work that you are not comfortable doing.
DIY Auto Body Tutorials
"Coming together is a beginning; keeping together is progress; working together is success."
`Henry Ford
LearnAutoBody is offline   Reply With Quote
Old 06-15-2012, 08:29 AM   #4
hijack123
hi,dnt ask me.. i m not ur realtive or frnd
bye
thuki hui car
hijack123 is offline   Reply With Quote
p0447 what is it? chaurik V70 0 12-13-2011 11:24 AM
