Go Back   Automotive Forums .com Car Chat > Cars in General
Old 10-23-2017, 10:21 PM   #1
T.C.
Help with trailer wiring: It works when first wired-up, then stops working
I'm having trouble wiring up the lights on a trailer. I have a 4-way connector, and I believe I've wired it up correctly:
- White to the trailer frame
- Brown to the tail lights
- Yellow to the left turn signal
- Green to the right turn signal
I verified this wiring against the instructions at http://www.therangerstation.com/tech...erLights.shtml. Unfortunately, it doesn't work. The tail lights, left turn signal, and right turn signal work when I first wire them up, but not afterward.
To elaborate: If I turn on the left turn signal on the car, then connect the yellow wire, the left turn signal on the trailer works fine, but only until I turn off the turn signal at the car. After that, the left turn signal on the trailer is unresponsive when I turn the turn signal back on. The same is true of the right turn signal and the tail lights -- they work as expected when I first wire them up, but stop working as soon as I turn off the turn signal or lights.
In all cases, I can disconnect the wires and reconnect them exactly as before, and the lamp in question will work properly again... until I turn it off and try to turn it back on. This tells me I haven't burned out a bulb or a fuse. At all times, the car's tail lights and turn signals work exactly as they are supposed to.
I am baffled by this. Does anyone have an explanation for why my trailer lights might work when first wired-up, but then stop working?
Some details: The car is a 1996 Nissan Pathfinder. The wiring harness on the car is an aftermarket T connector which I installed myself (see https://www.carid.com/curt/3-wire-t-...mpn-55361.html).
-TC
T.C. is offline   Reply With Quote
Old 10-24-2017, 10:00 AM   #2
aleekat
Re: Help with trailer wiring: It works when first wired-up, then stops working
I would check the continuity of the ground on the vehicle that you used.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Old 10-27-2017, 02:18 AM   #3
brcidd
brcidd's Avatar
"Ditto" Bad ground is most common trailer lighting issues.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 11-01-2017, 02:14 AM   #4
T.C.
Thank you for the suggestions. However, it looks like I have good continuity to the ground. I used an ohmmeter to measure the resistance between the ground of the flat connector and one of the bolts underneath the plastic threshold for the rear hatch (the only place I could find exposed metal). The meter read 0.9Ω. My meter has a continuity test feature which sounds a tone when there is low resistance. Using that feature, there was a strong, continuous tone. If I should be testing the ground wiring some other way, please let me know.
Is it possible that my T-connector is defective? (https://www.carid.com/curt/3-wire-t-...mpn-55361.html) The T-connector includes a literal black box that was described as 'a circuit-protected converter'. Might that be 'protecting' the circuit by shutting it down, perhaps in the way a ground fault interrupt does?
Old 11-03-2017, 11:00 AM   #5
aleekat
Website says it has a one year warranty. I would contact the manufacturer. They may have seen this before.
