Old 05-24-2021, 10:59 AM   #286
Scale-Master
Scale-Master's Avatar
Re: Lola T-70 Mk III
There is no joint. I turned it on the lathe.
Scale-Master is offline   Reply With Quote
Old 05-26-2021, 03:45 PM   #287
Scale-Master
I made the tailpipes. I bent steel armatures to form the tubing from the insides. The ends are brass.
Old 05-27-2021, 09:06 PM   #288
Scale-Master
The rear section seemed like it needed something more, so I freehand drilled a dozen holes in the rear panel. For a part that is based on a kit piece, I'm somewhat surprised how much scratch-work it has on it now. It didn't start out in my plans that way, but such is the nature of this project.
Old 06-11-2021, 10:13 AM   #289
Scale-Master
I designed the spokes for the steering wheel in SolidWorks from a real one I liked and printed a master.
This is a resin copy I cast from it with the aluminum rim I turned. I milled out three areas in the rim for the spokes to fit into.
Dry fitted together.
Old 06-17-2021, 08:41 PM   #290
Scale-Master
Shoulder belt anchor bar.
Shoulder and lap belt anchor hardware.
And the buckle sets. All scratch-built.
Old 06-18-2021, 11:49 AM   #291
Scale-Master
The kit seats are both the same.
I notched the inboard edges for shifter clearance and cut holes for the lap belts.
They needed some cushion detail. I thought I could use the pre-scribed sheet plastic I used on the camper I built last month, but it was so brittle (old stock I guess) it kept snapping, and not just in the recessed lines. I hoped to do each in two pieces but it was more like eight per seat.
The indentations needed to be scribed a lot deeper and some curvature added.
Primed and on hold until painting.
Old 06-20-2021, 04:09 PM   #292
Scale-Master
Rather than C/F or Kevlar I went with the main body color for the seat backs.
Old 06-22-2021, 07:18 PM   #293
Scale-Master
The shoulder belt adjusters, made from scratch.
Old 06-24-2021, 07:30 PM   #294
Scale-Master
I painted the hardware and made the belts. The little hook latches for the buckles will be installed later with some other details; they are too delicate.
Old 06-25-2021, 05:11 PM   #295
Scale-Master
New dash made from scratch, discarded kit dash above (black). I'm using the kit gauge pod with modifications.
Old 06-26-2021, 04:52 PM   #296
Scale-Master
I machined the AutoMeter gauge bezels out of aluminum. The air vent and lower gauge housings are brass.
Old 06-26-2021, 07:43 PM   #297
kans0002
kans0002's Avatar
Still following and still blown away! Keep it up!
kans0002 is offline   Reply With Quote
Old 06-27-2021, 02:06 AM   #298
Mpfiend
I've been following from the beginning and am amazed at your work.
I look forward to every update.
K.
Mpfiend is offline   Reply With Quote
Old 07-01-2021, 08:33 PM   #299
Scale-Master
Thanks guys! I really appreciate it!
While doing a periodical mock-up of the main parts I noticed the front end had somehow incurred five fractures around the wheel well, headlight and driving light openings. I know this blue plastic is very brittle, but this was a surprise.
As much as I intended to install the headlight buckets after the body was painted I went ahead and did so after repairing the damage for added strength.
Old 07-03-2021, 12:46 PM   #300
Scale-Master
I made some Jabroc wear strips for the bottom of the chassis.
