06-03-2010, 08:33 PM | #16 | |
Re: which one is better? energy suspension or powerperformancemotorsports.com
Ok Can you guys help me with this please.
I am going to buy the following parts but I don't know which ones I will need in quantity of 2 and which ones I will need just 1. If any one of you would fill it out and post a reply back it would be really nice. I want to cover both left and right side. - Tie Rod End Adjusting Sleeve ________ - Center Link ________ - UPPER Ball Joint ________ - LOWER Ball Joint ________ - FRONT LOWER Control Arm Bushing ________ - FRONT UPPER Control Arm Bushing ________ - REAR LOWER Control Arm Bushing ________ - REAR UPPER Control Arm Bushing ________ - Idler Arm ________ - Stabilizer Bar Bushing ________ - Ball Joint Dust Boots ________ - Outer Tie Rod Dust Boots _______ - Front Sway Bar End links _______ Thanks alot guys. |
06-04-2010, 12:29 AM | #17 | ||
Dust boots should come with the ball joints.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
06-04-2010, 02:24 PM | #18 | ||
I took a 7/8 wrench but it was a little small, so what is the next size from 7/8 wrench? I believe that one would fit. I took the adjustable wrench and once I got it to fit around fine, I measured it and it came to an almost 3cm, not quite 3cm but just short of 3cm. So does that mean I should get a 1" bushing for the stabilizer bar? let me know thanks ALSO WHAT SHOULD I GET NOW AS FAR AS BUSHINGS GO BRAND WISE???? MOOG OR ENERGY SUSPENSION? I AM CONFUSED BECAUSE THE MECHANIC I WENT TO TOLD ME TO GET POLYURETHANE ONES? AND THEN I READ IT ON FORUMS WHERE THEY SAY IT SQEEKS, MY CAR WONT BE FOR RACING OR ANYTHING IT WILL BE ONLY FOR DAILY DRIVING PLEASURE USE. PLEASE HELPPPP I HAVE SETUP A CART WITH ALL MOOG BUSHINGS SHOULD I GO WITH IT? OR ENERGY SUSPENSION. THANKS. Last edited by DJShyn3; 06-04-2010 at 11:51 PM. |
06-05-2010, 12:18 PM | #19 | ||
3cm = 1.18" so it might be a 1 1/8" diameter bar
06-05-2010, 01:12 PM | #20 |
06-05-2010, 04:16 PM | #21 | |
06-05-2010, 05:21 PM | #22 |
