Go Back   Automotive Forums .com Car Chat > Honda > General Discussion
Old 05-25-2023, 10:30 AM   #1
rp2121
HONDA PILOT 2005 ALternator?
My 2005 Pilot is clicking when attempting to start it. The battery is new, the alternator was replaced 4 years ago and the starter was replaced 3 years ago. The car will not take a jump.
Any thoughts??
Thanks so much!
rp2121 is offline   Reply With Quote
Old 05-25-2023, 02:55 PM   #2
aleekat
Re: HONDA PILOT 2005 ALternator?
You need to put a voltmeter on you battery. Static then cranking voltage reading. And if you get it running, running reading. Sounds like your alternator not charging and killed your battery. A really depleted battery you won't be able to jump.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Old 05-25-2023, 04:03 PM   #3
rp2121
Thanks for the response.
If i put a new battery in and it still doesn't take a jump it wouldn't be the alternator correct? A bad alternator should at least take a jump even if it dies quickly?
Old 05-25-2023, 04:48 PM   #4
Stealthee
Your worst nightmare
Stealthee's Avatar
Check your connections. Make sure you have good grounds.
Stealthee is offline   Reply With Quote
