Old 02-07-2016, 08:38 AM   #16
Marcelo Teles
Marcelo Teles's Avatar
Re: 1968 McLaren M7A, Bruce McLaren. Model Factory Hiro, 1/20.
Wow!!! Amazing!
Marcelo Teles is offline   Reply With Quote
Old 02-07-2016, 03:55 PM   #17
pgarat
pgarat's Avatar
Hi,
Thank you very much mates.
Hi Rob, how are you?
Small progress on the gearbox.
Dry bushes with Polished Steel , Polished Alu from chez Humbrol Metal Cote.
Oil job with Rembrandt (Extra fine) Sépia and W&N Artists Ivory Black, Gris de Payne et Outremer.
Of course RB Motion bolts and washers were used.
Pics will tell more:
More soon.
Pascal
pgarat is offline   Reply With Quote
Old 02-08-2016, 03:39 PM   #18
gasdriverca
gasdriverca's Avatar
Send a message via Yahoo to gasdriverca
Insane detailing......love it!
Projects on the bench:
Scania 124 Push Axle with Scratch built Curtainside Trailer
Opel Calibra V6 DTM (Reuter)
Panasonic Toyota TF102 (Mcnish)
gasdriverca is offline   Reply With Quote
Old 02-13-2016, 04:12 PM   #19
pgarat
pgarat's Avatar
Hi,
Thank you
First of all, sorry for the (very!) poor quality pics...
I will try to make some better tomorrow.
Brake calipers and the stub axle (?) were chemically burnished.
Brake calipers were "stolen" to the M19 in order to replace those supplied in the kit.
rear axle parts are prepared and drilled... too much drilled!
I had to play with the low temp solder in order to fill the hole in the lower part, then sand, but now it's ok.
Brass knobs for the dampers.
Same method than those done for the Ferrari 312F1.
They will be burnished.
Primer and paint for everybody:
More soon.
Pascal
Old 02-14-2016, 04:43 PM   #20
pgarat
pgarat's Avatar
Hi,
Few progress.
As usual, radiator is filled.
Better pics than those from yesterday:
Weld lines added.
It's a bit rude for now, but with primer and flat black it should be ok.
If not... I'll undo it and will make the weld lines with the iron as it was tested initially.
Dampers almost finished.
A Koni stucker was added...
Just now need a light oil wash.
More soon.
Pascal
Old 02-15-2016, 11:45 AM   #21
gasdriverca
Looking real nice 👍
How is it working with those weld line? I've never used them myself but they do look good.
Old 02-15-2016, 03:31 PM   #22
pgarat
pgarat's Avatar
Hi,
Thank you
Weld lines are pretty easy to work with.
Those ones are metal type from Top Studio and those seen earlier in the WIP and on the 67' Ferrari 312 F1 were from Archer.
Primer and paint session .
Front dampers clear coated:
Not that happy with the weld lines I find pretty rude and out of scale...
I will decide what to do after "weathering" job on this side exhaust.
Pascal
Old 02-16-2016, 05:01 PM   #23
pgarat
pgarat's Avatar
Hi,
Update on the Gearbox/Engine assembly and test fit: cooool!
Time for pictures:
Maybe I will do something like that for the weld lines:
More soon.
Pascal
Old 02-18-2016, 04:16 PM   #24
pgarat
pgarat's Avatar
Hi,
This is the other solution regarding the exhaust weld lines.
I made a real flat weld line with low temp solder.
It was then masked with liquid mask and treated with burnishing product.
A mask a bit larger was then done before shooting primer and mat black
I think I will add few accessories:
Pascal
Old 02-20-2016, 04:47 PM   #25
pgarat
pgarat's Avatar
Hi,
Not that happy with the former result: Plouf! gone to swim in the cellulose thinner.
New black layer sprayed
ZP Black on the gloves too:
... and Pure White on the helmet:
Maskol off, ZP Translucent blue and W&N Ivory black wash down on the weld lines area:
Not decided yet...
Couldn't resist to compare the DFV with the 500 F2 engine!
Should have done the same with the Tipo 218 V12 of the312F1...
Pascal
Old 02-21-2016, 04:47 PM   #26
pgarat
pgarat's Avatar
Hi,
Transmission progress:
Pascal
Old 02-22-2016, 04:08 PM   #27
pgarat
pgarat's Avatar
Hi,
Oil coooooler; A/N fittings & braided line!
More soon.
Pascal
Old 02-23-2016, 08:58 AM   #28
gasdriverca
Nice nice nice what more can I say.
Old 02-24-2016, 04:15 PM   #29
pgarat
pgarat's Avatar
Hi,
Thanks
Transmission is now almost done.
Once the exhaust finished, engine and gearbox can be assembled, then fasten to the rear bulkhead.
More soon!
Pascal
Old 02-25-2016, 02:00 PM   #30
ianc911
Smashing as usual!
ianc
ianc911 is offline   Reply With Quote
