| Latest | 0 Rplys |
How-to | Technical Info A wealth of information at your disposal. |
03-31-2006, 03:36 PM | #16 | |
AF -Advisor
Re: BALL JOINT REPLACEMENT HOW TO (w/ pix)
Just want to add that the ABS sensor has an electrical connector about 1.5 feet up on the frame which is the best place to disconnect cause those allen screws may break off if rusted like most. I had to use a puller on the lower ball joint too. Best time to inspect and replace the CV axle too.
04-03-2006, 11:03 AM | #17 | |
Great post! Might be doing this soon!
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
08-16-2006, 06:06 PM | #18 | |
Hey guys!!
I have a 96' s-10 Blazer and am getting ready to put a 2" Superlift on it. This is a great post as I have never done the ball joints before and I have ordered Moog replacements for mine. Top should be easy as I can install them on the upper control arms that come with the lift kit prior to installing the upper control arms on the truck. The bottoms were replaced before by the previous owner so hopefully those will be a little easier to get out. Anyway, stupid question, the ball joints simply slide into place, or do you have to press them in with a tool? I did not see a post or how to in here about installing the Superlift 2" kit, so I'll ge the camera and takes some pictures so hopefully it can someone else down the line Thanks, Marcinko |
08-17-2006, 05:18 PM | #19 | |
Nice !! and thanks for taking the time out to take the pictures. Pretty soon we will be able to access a complete video libary for part replacement. Thanks again!
08-17-2006, 05:59 PM | #20 | |
re. seating the caliper piston, i remove the 2 caliper bolts, then use a large screwdriver between the outer pad & the caliper & slowly pry the piston back in in a few seconds. (AFTER I remove the master cylinder cap & check the fluid level) no messin' with the c-clamp & piston goes back in straight
08-17-2006, 08:46 PM | #21 | ||
AF -Advisor
C-clamp is the best method seeing it pushes it back uniformly.
1995 Factory Blazer Service Manual for sale, PM if interested. |
08-18-2006, 03:28 AM | #22 | ||
94 Firebird: 3.4L 220,000 mi 95 Blazer: LS 2DR/2WD 210,000 mi 96 Trans Port: work in progress 97 Silverado 4X4 Ex/cab: 200,000 mi 05 Malibu: 98K mi 08 Chevy Van: Direct TV work van Last edited by wilfie27; 09-10-2006 at 06:31 PM. |
08-23-2006, 05:29 PM | #23 | |
lt, if you go at the center of the pad, on the outside (non-piston side)of the rotor it can only go in straight.
08-28-2006, 05:11 PM | #24 | |
I don't know if I even want to fool with something like this or not. I am due for all ball-joints to be replaced. :/
1999 Blazer 4x4 LS "Blackie" Monroe Reflex Shocks Moog U/L Ball Joints K&N FIPK Gen 2 Cold Air Intake Flo-pro Soundpro exhaust Optima Redtop 132k miles and still rolling.... |
08-28-2006, 07:50 PM | #25 | |
It really isn't all that bad to do them, it just takes some time and patience. Plan on a whole day to do all four. The biggest pain is chiseling out the old rivets - if you have access to an air chisel it makes it easier.
I ended up pulling the hubs to have better access to the lower ball joints - but it isn't required. Keep in mind that if you are doing it have the 36mm socket on hand for the axle nut.
billibong 99 4X4 Blazer LS Vin W Repairs: U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference) F & R Brakes and Rotors at 110,000. Infinity Speakers to replace the blown factory sets. 162K+ and still kicking. |
08-30-2006, 07:55 PM | #26 | |
Yes that was a nice thread a some very good pictures too. The part where you was pounding the pickle fork with the hammer on the bottom ones tryung to break them loose, I know everyone don't have compressed air but get one of those forks and a air impact driver cuts out alot of work. Once agan nice thread.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '98 Pontiac Grand Prix GT, 3.8 '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
10-31-2006, 10:19 PM | #27 | |
Before you start removing your ball joints do you have to unload your torsion bars?
2000 Olds Bravada 4.3w, 215,000 (May 09) 2005 Yamaha Vmax 1200cc, 23,500 (May 09) 2004 GMC Sierra 1/2ton 4.8"V", 70,000 (May 09) 1983 Kawasaki LTD KZ750-K1 750 in-line twin 22,000 (June 09) Although I don't have much automotive knowledge to offer in return for all the help I get from these forums, I am a master electrician, so if anyone needs electrical advice I would consider it my rent here to share. Just PM me. |
11-01-2006, 05:09 PM | #28 | |
You do not need to unload your torsion bars.
94 Firebird: 3.4L 220,000 mi 95 Blazer: LS 2DR/2WD 210,000 mi 96 Trans Port: work in progress 97 Silverado 4X4 Ex/cab: 200,000 mi 05 Malibu: 98K mi 08 Chevy Van: Direct TV work van |
11-01-2006, 05:31 PM | #29 | |
all you do is support the unload the steering knuckle by placing jackstands under the lower control arms then you can take them apart
and yes i am a ASE Master Auto Technician 1996 chevrolet silverado 5.7L 4x4 nothin but a k&n for now i just got it |
11-01-2006, 06:36 PM | #30 | |
So if I were going to go as far as to replace control arm bushings at the same time while I have things apart, then would I need to unload the torsion bars? Could I unload them by breakign the balljoints free while a jack is supporting the lower control arm, then lower the jack to relieve the tension?
