Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 12-15-2017, 08:43 AM   #1
Klajd
Throttle Code
Hi everyone,
I just found out this forum and THANK YOU ALL for all the help you provide to each other
I am having some problems with my Chevy Malibu 2009 LS 2.4L with the code P2135. The car shakes and everything and the engine light is on, engine power reduced and stability traction. I am trying to figure out what is the problem exactly and try to fix it. I have already cleaned up the throttle body since that seemed to be the main problem online but I am trying to figure out if there is a sensor problem that I need to replace or connection issue because I read a lot of people replaced several parts and then still had the problem.
So these are the data I have and I really appreciate any help you can give
Code:
P2135 (Throttle / Pedal Posiion Sensor / Switch A/B Voltage Coorelation
Freeze Frame Readings:
DTCFRZF: P2135
FUELSYS1: CL
FUELSYS2: N/A (since I have a 2.4 engine so no second system)
LOAD_PCT(%): 29.4
ECT(°F): 144
SHRTFT1(%): -3.1
LONGFT1(%): -0.8
MAP(inHg): 10.0
RPM(/min): 990
VSS(mph): 0
SPARKADV(°): 5
IAT(°F): 52
MAF(lb/min): 0.663
TP(%): 20.8
RUNTM(sec): 33
EVAP_PCT(%): 0.0
FLI(%): 40.4
WARM_UPS: 0
CLR_DIST(mile): 0
EVAP_VP(inH2O): 0.440
BARO(inHg): 30.1
CATEMP11(°F): 924.80
VPWR(V): 14.965
LOAD_ABS(%): 24.0
EQ_RAT: 0.999
TP_R(%): 6.3
AAT(°F): 32
TP_B(%): 25.9
APP_D(%): 17.6
APP_E(%): 8.6
TAC_PCT(%): 9.4
Please if you are a mechanic or had a problem like this before please let me know. I appreciate any help or suggestion or recommendation.
Klajd is offline   Reply With Quote
Old 12-16-2017, 01:37 PM   #2
maxwedge
A990 racer
Re: Throttle Code
Sell the throttle sensor on the pedal does not correlate with the amount of opening on the actual throttle. This would require further diagnosis. Google that code for the info to pinpoint the problem.
Tags
chevrolet , code , malibu , sensor , throttle
