Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-27-2006, 09:52 AM   #1
RayQix
Send a message via AIM to RayQix Send a message via Yahoo to RayQix
94 RAM 1500 Cruise
Hey....(Tony or anyone else)...
What does anyone know about why a 94 Ram1500 might not have the Cruise working? I've checked the fuses under the dash & the hood...I even changed the cruise "head unit" under the battery...and according to my neighbor (who had a working multimeter) there was no power to the "head unit".
But, methinks, if the cruise isn't available below 30-35mph (been awhile since I had a car with cruise that worked) i'm not sure if it would actually HAVE power sitting still in a driveway.
Anyone...? anyone....?
thanks
RayQix is offline   Reply With Quote
Old 02-27-2006, 11:30 AM   #2
tony36
Send a message via MSN to tony36
Re: 94 RAM 1500 Cruise
I don't think you will show power to the head unit sitting still. The cruise will not engage below 35mph. I don't remember for sure if this unit has vavuum to it but if it does you may have loss of vacuum. I think it may also have a relay along with fuses, I will check and get back with you. If the relay is bad you will loose cruise.
tony36 is offline   Reply With Quote
Old 02-27-2006, 11:51 AM   #3
tony36
You could have loss of vacuum. You might check the vac reservoir and your lines. I check vac lines with starting fluid. With the engine running spray it on the hoses, if there is a leak you will hear a difference in the engine. How is your speedometer working? It may have something to do with a speed sensor also. It could have an efect. I once had mine go bad, the speedo still worked but the trans would not shift out of first. Sounded strange to me but it could be bad and the cruise does work from that.Let me know what you find.
Old 03-04-2006, 03:19 PM   #4
ramdriver
Any development on this? I am curious to know about the relay that was suggested. Where is it located? Did you have any luck fixing it? Inquiring minds want to know!
ramdriver is offline   Reply With Quote
Old 03-04-2006, 10:05 PM   #5
RayQix
Okay...
Prior to changing the "head unit" for the cruise, I did check to see if I had vacuum....which I do. It goes all the way back to the pass side of the 318. Now prior to this, the HVAC vacuum had melted closed, which i've since repaired and it's fine ...which i thought maybe the two were related.
The "Vacuum Reservoir" is under the windshield, if I understand the diagram correctly. How will I know if that's working or not, or will it not work even if my heater goes from DEF to FLOOR and back again (also vac controlled)?
Speedo is fine...no problems...but the truck doesn't shift real easy out of 2nd into third on accelleration -- but that is an intermittent problem and a trans shop gave me a nightmarish estimate about replacing it. (it works at least for what i need it to, i'm not going to worry about it)
Lemme know...i forgot to check back on this as i've been in the middle of a few other projects.
THANK YOU TONY!
-- Ray --
Old 03-05-2006, 03:33 PM   #6
tony36
it is possible your speed sensor is bad, it does not have to quit working entirely to send bad signal, that could possibly effect tranny and cruise. Check canister by spraying it with starting fluid while motor is running, you can check any vacuum this way, if engine idle changes up or down, you have a leak.
Old 03-05-2006, 05:52 PM   #7
RayQix
Will have to give that a shot in the next couple days...supposed to snow tonight & tomorrow...dont wanna get under there unless it's life-or-death.
Would that intermittent speed-sensor problem be okay when it's cold or warm and then bad when it's the opposite?
>Ray
Old 03-05-2006, 09:16 PM   #8
tony36
>Ray
Temp shouldn't have an effect but I guess its possible. It is electric. If you change it, its simple, unplug harness, unscrew sensor, just have the new one ready because fluid will escape nad you want to lose as little as possible. Did you find out if there was a relay for that? I should sak, when you start your truck and push the on button for the cruise, dose the cruise light come on on the instrument panel? That tells you that it is activated and ready to use. If it doesn't come on then I think your problem is electrical, the button or something.
Old 03-05-2006, 11:25 PM   #9
BleedDodge
BleedDodge's Avatar
Send a message via MSN to BleedDodge
If the throttle position sensor gives wacky readings it will cause the cruise to malfunction. It will cause the cruise to act dumb, and then it just won't work at all.
Check your throttle sensor.
My Mopars
BleedDodge is offline   Reply With Quote
Old 03-06-2006, 06:47 AM   #10
ramdriver
Is it possible for the throttle position sensor, or even the speed sensor to malfunction and give wacky readings without tripping a code and displaying check engine light? Just curious..My truck has no cruise display when button is pushed but what has got me thinking is that I have noticed a bit of a stutter when tranny shifts gears...especialy when pulling the ski-doo trlr under acceleration. After the input on this thread it makes me think the two are related, but I do not have any codes showing...What do you think?
Old 03-06-2006, 06:57 AM   #11
RayQix
I don't have a light of any kind for the Cruise (that I know of). I know in the newer ChryCo vehicles, there's a light comes on when you hit the Cruise (usually on the odometer readout or somewhere...but haven't looked for the light either.
I just went out with a flashlight to see if I could find a light on the Instrument Cluster...nada found anywhere there SHOULD Be one.
The Relay would be a good start...but i'm not sure where to look for it (under hood or under the truck itself)...
Since we didn't get the snow we were expecting, I might be able to check the vacuum and see about whether the vac reservoir is bad (you had mentioned about the engine rev going up or down).
As far as the TPS...not that thing again...(ref to another problem on TWO separate cars (concorde & my no-longer-owned Saturn)).
Old 03-06-2006, 01:24 PM   #12
sandman96
I own a 94 Ram and have never seen a cruise light on my instrument panel. As far as I know there ins't one.
sandman96 is offline   Reply With Quote
Old 03-09-2006, 12:43 AM   #13
tony36
I was not sure about the light, my 99 has one to tell if cruise is on ready to use. Sorry about that.
Old 03-09-2006, 12:56 AM   #14
corning_d3
Send a message via Yahoo to corning_d3
It could also have a bad cruise control switch or wiring(In steering wheel) or clockspring(located behind steering wheel). Before you remove the airbag, disconnect the neg. cable from the battery first, and wait 2 min. to let the system capacitor discharge.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
corning_d3 is offline   Reply With Quote
Old 03-09-2006, 06:57 AM   #15
RayQix
Would there be any help in just jumpering the cruise power leads to live power (battery or fused link) to check it...or maybe just to rig it in order to get it to work?
>Ray
