Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 04-06-2006, 01:08 PM   #1
gcrorig
'00 QX4 Power Window and Blower Died
My 2000 QX4 front driver side power window died. I've read about switch issues. How do I remove it? Also, the HVAC Blower just stopped entirely. Any fuse for this? Please advise. GR
gcrorig is offline   Reply With Quote
Old 04-08-2006, 03:28 AM   #2
FixUrNissan
FixUrNissan's Avatar
Re: '00 QX4 Power Window and Blower Died
i am assuming you have auto air being it's a QX. Did all Blower speeds fail and you only have high? or you have no speeds at all . Do the controls still Illuminate as if it works , if it's auto air. There are fuses you can check , if you only have high speed you'll need a blower motor resistor. You can also check to see if the blower motor is getting power , it's only 2 wires . other than that if i had more info i could maybe be more helpful.. GL
FixUrNissan is offline   Reply With Quote
Old 04-10-2006, 04:28 PM   #3
gcrorig
Thanks a bunch. Yes, Auto air. The blower completely stopped working while the blower indicator lights operate normally. That is the blower speed indicator will change from one paddle to 4 depending the system need. No air, no how.
I pulled out and put back ALL the fuses in the pasenger compartment behind the coin tray hoping for a bad connection issue. The two 15 amp fuses marked for the blower appeared fine. I haven't checked all the fuses under the hood as there doesn't appear to be one fuse marked for the blower.
Any thought on the power window?
Much Appreciated,
GR
