Go Back   Automotive Forums .com Car Chat > Ford > Festiva
Old 07-20-2005, 08:07 PM   #31
jessb
Re: Festiva
Originally Posted by 92Festiva
I have a 1992 ford festiva and i got it at 215k km it now has 250k km i have had to replace the tranny alternator and starter and the thing eats mufflers, other then that it now runs perfect starts up really easy great on gas 20 dollars canadian a week love that car
I have only replaced the muffler 1 time on my 90 Festive (now at 265,000+), original transmission, alternator and starter. No rust at all on it (no road salt here in the South.) I drive 420 mile each week to and from work. The gas gage hasn't worked for several years so I reset the odometer at each fillup. When the mileage is between 390 and 400, I fillup and check the MPG. During the last year I have gotten as high as 51 MPG and as low as 42 MPG between fillups. Average is right at 46 MPG. Other than routine maintenance, the only major problem has been the crankshaft keyway problem noted in an earlier post.
Items I replaced at about 240,000: Left CV Joint, Ball joints, Front Rotors, Rack and Pinion Steering (rebuilt) and tie rod ends. Front and rear wheel bearings, Clutch and Pressure plate, pilot and throw-out bearing.
AC sill works but not as well as there is a slow leak...Freon is getting too expensive, so I plan to change system to R134A this winter. Also the right CV joint is starting to click, so I will replace that also. The struts still seem to be OK but I will also replace them just to make it feel better. Plan to keep this car for my 2 year old grandson to driver when he starts college (his father drove it during his college years.)
jessb is offline   Reply With Quote
Old 10-26-2005, 06:49 PM   #32
danmdevries
Send a message via AIM to danmdevries
Re: Thinking about buying a 92 Festiva
www.geocities.com/danmdevries/danny.html
There's a very long story behind that car. I lived in an 89 Subaru Justy (same car as a festiva) for 3 months in the winter. It does tip easily. I used to be able to put it up on two wheels leaving work. Tell ya what though, I'm surprised at how well that car held up in that wreck. I was doing 55ish around a bend, hit a patch of ice and lost it, it caught traction and rolled 3 times, skidding on its roof backwards off the road into a ditch and then flipped back onto the wheels sideways and then rolled a 2 or 3 more times before resting on its roof.
But while owning the car (before losing the back half of the car to a tree that fell in a storm -see the "custom" new back half? :-P) it got between 45 and 50mpg! I rarely had it above 60 and drove like a grampa because if I stomped on the gas pedal it would die for about half an hour...
They're queer, quirky and slow. I'd steer away from an AT, the 5 speed makes it much more driveable. But they've got a certain appeal in that you'll never forget owning one and the looks you get while driving it.
danmdevries is offline   Reply With Quote
Old 11-16-2005, 09:14 AM   #33
IdealSociety
Send a message via MSN to IdealSociety
Re: Re: Thinking about buying a 92 Festiva
i have a MODIFIED 1992 ford festiva and have been driving other festivas since i got my license... i have done almsot anything to a festiva that can be done and i will tell you they are the easiest car with the lowest priced parts i have ever owned (i also have a mistubishi 3000GT VR4, very pricey and very fast!)
in the winter the festiva with an upgrade to a tall skinny 13" tire becomes a monster... i live in minnesota and last year we had 2 feet of snow fall in a massive snow storm in march... right in the middle of it when the two main interstates were closed (I-35 and I-90) i took that little beast on a 100 mile trip to see my girlfriend, i passed semis and 4x4's, i had snow packed AROUND my motor in my engine bay, i hit drifts that were tall as my hood and still made it...
for winters they are great, i have a 89 chevy k1500 4x4 with a 5spd trans and my festiva gets three times its milage and gets stuck less lol...
and if its in that good of shape you can do what myself and many others have done, modify... the festiva was made in korea with mazda parts assembled by kia, so hence the mazda parts it has many interchangable and bolt on things that can be used from other cars.
many people want more power so they go with a light motor upgrade from a mazda 323 (1.6l instead of the festy 1.3l) which gives about 20hp more power. some go with a b6t (mercury capri xr2 turbo motor) which boasts about 130hp and high 13 second quarter mile times in the VERY light festiva...
i went with a less used 1.8l escort gt BP motor/transmission swap which has about the same hp and a little more torque as the b6t but without the turbo. all these motors WILL bolt up to the transmission and are cheap and common to find under 500$...
as for the comment on them being smaller than a metro... they share roughly the same volume (metro is 3 inches longer but festiva is 6 inches taller) headroom is wonderful, legroom is plentiful for both front and backseat passengers (shockingly ive had 300lb friends in back praise the roomyness of the little car) and after driving one you will love it, maintenance is low and as long as you take care of it they WILL last almost forever...
check out www.fordfestiva.com, ive been a member of their forums for years and they will answer ANY questions on performance, maintenance and durability you have. festivas are crazy little cars that can have alot done to them cheaply (12 second car for under 2000$ anyone?) not only that but they have personality to boot... then again... you could just buy a toyota and go with the crowd on page 1
IdealSociety is offline   Reply With Quote
Old 01-06-2006, 12:49 AM   #34
RavagePenguin
RavagePenguin's Avatar
Send a message via AIM to RavagePenguin Send a message via MSN to RavagePenguin Send a message via Yahoo to RavagePenguin
My Mom had one it has over 900,000 miles and still running. She bought it brand new. People told her the car wouldn't even last past 10,000 now look at it. Its had its typical high mileage car problems but nothing serious. She was some how able to get it to have 50 mpg. How we don't know it just did. Yes it is true its the worst car to be in accident with but they can take it. My Mom has driven that car real hard. It would jump hills easily past 50 mph. We took it down the backside of Mt. Lemmon. Anybody that lives in Tucson will know that going down the backside of that mountian is sucidal to the car with 4wd. The thing is still running. Currently my Aunt now owns the car. Top Speed of 120 can't beat that for a ecnocar. Once I get my current car fixed up I'm planning on buying the Festiva from my Aunt and doing a little engine modifications to it that would make this thing make people say "There is no way that car can go that fast".
RavagePenguin is offline   Reply With Quote
Old 02-02-2006, 09:59 PM   #35
wrestler
Cars are like apples...once in a while you get a bad one. Based on my experience with a '93 (bought new), they're very tough little cars. I sold mine with 210,000 miles (not km) and it ran perfectly. The reason I sold it is because without A/C, it's also a HOT little car to commute in when you live down South.
The crucial element with the Festiva, which I believe an earlier reader correctly described as a Maza 121, is GOOD MAINTENANCE. That includes timing belt changes at every 60,000 miles.
Another alias for this car is the Kia Pride. It is most definitely a Korean-built Mazda, wearing the Blue Oval, and '93 was the last year before Ford made the bad decision to opt for the Aspire. Very inferior in comparison, though essentially still a Kia Pride. Very few mechanical parts will inter-change.
On a '92 with that mileage, check the timing belt maintenance (change it if you don't know the history), check the lower control arms (grab the front wheels with the car on stands and try to shake them...wobbly is bad), check the tie rod ends simultaneously, listen for front bearing howl when you drive it, and check the clutch action...if it slips when hot, you need a new disc at least.
A little caveat for you about older cars...it's difficult to get factory parts after about 10 years (with the smaller Ford offspring anyway). The availability is planned that way and it makes older cars hard to maintain, because the aftermarket carries a very limited stock (a second reason why I sold mine).
If you just need transportation, and it has only minor problems, it's a keeper. Good luck with your decision. I can throw you a real challenge...find parts for an '89 Probe GT! They seem to gold-plate them and store them on Mars.
wrestler is offline   Reply With Quote
Old 09-09-2006, 02:25 PM   #36
gelcol
crx will go 35-40mpg.
gelcol is offline   Reply With Quote
Old 09-11-2006, 12:17 AM   #37
gelcol
40 - 50 crx hf.
Old 12-03-2006, 02:25 AM   #38
xsbc63x
i own a 93 festiva, bought it in march and been driving it daily to work and back have had 0 problems with it til the other day the timing belt jumped time but i put it back in time and it runs good, gets about 38mpg and 20bux fills the tank!
also extremely cheap on insurance
xsbc63x is offline   Reply With Quote
Old 05-20-2007, 10:48 AM   #39
Turbofestiva
Turbofestiva's Avatar
Ford festivas are really good cars in fact its my favorite car. And yes it is a Mazda 121 but for now i just have a civic hatch
Turbofestiva is offline   Reply With Quote
Old 05-20-2007, 10:51 AM   #40
Turbofestiva
oh and one more thing is that ford festivas get 40+ highway mpg and a little less in the city.
Old 05-23-2007, 04:08 AM   #41
Davescort97
Escort guy
What is the displacement of a Festiva engine?
Davescort97 is offline   Reply With Quote
Old 06-08-2007, 09:42 PM   #42
carhacker
Festiva 1.3 liter engine, 64 HP in a 1750 pound car.
I owned my 93 Festiva for 11 years. 5-speed rated 38 mpg city and 38 mpg highway. Even in 5th high revs at highway speed. Lots of pep in the city up to 35 mph.
Very good on snow as long as ground clearance not an issue.
I grinned a lot driving it. It was fun and the big windows meant lots of visibility. Park anywhere, drive on sidewalks, everything worked right.
I would still own it except Ford mechanics here treated it like an illegitimate child. A year after Ford stopped supplying parts I sold it.
Problems: Front brake rotors are part of the hub. If you can't get the rotors turned while on the car and need to replace it's a lot of hours and ingenuity required.
Rear brakes have a lever that will rust up even if like me you use the parking brake every time you stop. Fortunately they are easy to work on.
Some local guy has turbo-charged his white Festiva -there are some insane Festiva project cars out there.
carhacker is offline   Reply With Quote
Old 07-11-2007, 10:59 AM   #43
Turbofestiva
81 cid
Old 07-11-2007, 11:02 AM   #44
Turbofestiva
I dont know why but the festiva is still my favorite car but i dont have one right now! but i do have plans for a turbo one but with out any swap i want to keep the 1.3 no one keeps that i like to stay with stock blocks.. my goal is 200+hp
Old 01-09-2008, 04:05 AM   #45
festivanut
hey mate, i own a '96 festiva trio with a 5 speed manual. i paid $5000 australian for it with 105000 km's on the clock. it's a relatively good little car, cheep to run and easy to maintain. our petrol/gas is at 129.9 cents a litre and it only costs me aout $40 AUD ($35.4621 CAD) to keep it going for a week and i get about 400-500 km's to a tank. the only trouble i've found with it is that the cv boots wear out relativly fast, i'm on my 3rd set in about 18 months, but they only cost about $160 ($141.838 CAD) supplied and fitted to replace. that festiva for $800 CAD ($902.230 AUD) is a bargain. try your hardest and good luck.
festivanut is offline   Reply With Quote
