Old 08-15-2020, 08:53 AM   #16
Serioga
Serioga's Avatar
Re: Ironhide TopKick C4500
Hi Gents!
I have a holiday today. stratos75 have made wheels for this project!
Many thanks to Michael Petrenko! Enjoy the pictures!
"Precious and fragile things Needs special handling.."
Serioga is offline   Reply With Quote
Old 03-11-2021, 02:13 PM   #17
Serioga
Serioga's Avatar
Thank you, Francis!
Hello, colleagues!
It's time to start a cab. As I came to assemble a 1999 Silverado on a nearby topic, and Silverado & TopKick have the same bed, it is better to take measurements*from Silverado bed, when it not glued to frame. And before that it's better to make cab.
Armed with PDF-files
Cab have rounded sides...
...so I desided to cut them from vent tube
Printed drawings and glued on
Back wall has difficult* shape. It has a step outwards to increase cab space 2,5 inch more. So I divided this element to 3 pieces. The first one, which is reflecting the back contour of a cab I cut from styrene. It was mistake.
It don't keep*flat shape. *Next I tried transparent plastic* from candy box.
Here is how* looks pattern.
Cutouts are not ready jet
Sandwiched back wall.
By the way, does anyone have a picture of 2000 TopKick's firewall? The only photo I could find was this
...but I'm afraid it's 1990 TopKick.
Old 08-03-2021, 03:30 PM   #18
Serioga
Serioga's Avatar
"Hi, Gents!" (c)
Have found some time to scratch more plastic.
Here is roof*sandwich*
.. and back wall
And moving forward I've found difficulties: the roof**bends forward just behind the stamping and because it curves in two planes, I had to make a cutout
But this solve the probleme partly.*
Roof bending should be smooth and have bigger angle. So I inserted 1mm square rod between layers.*
different view
Also right* stand was accidently cut in process (marked by arrow) and glued back/**
Final stage so far, but* stands should be bended more.
I pulled myself together and made a slipway
Further upgrade
Well, fitting
Thank you* for viewing!
Old 08-31-2021, 09:02 PM   #19
360spider
360spider's Avatar
Wow! That is some scratchbuilding!
Very cool.
ItalianHorses.net
360spider is offline   Reply With Quote
Old 11-23-2021, 10:08 AM   #20
Serioga
Serioga's Avatar
Thank you, Alex!
Let's continue!
I decided that it is easier to process panels individually than together. The stiffness is greater. I sanded off the excess*plastic on the roof.
The front side of the roof had to be lifted with putty.
I'm slowly processing it, but this is not the final yet
I took care of the sidewalls. I started making stamping lines. The upper one:
... bottom one
So - it 's clearer
Next - putty in the right places, but first - are masks
Then the most dreary thing for me: putty, sanding, putty, sanding*...*
Thank you for watching!
Old 03-19-2022, 11:14 AM   #21
Serioga
Serioga's Avatar
Hello, Friends!
There is nothing to show about plastic today, but I will show the first modest experience in 3D modeling.
Front hub
Many thanks to Mikhail aka Stratos75! He has drawed the cap.
It was already faster with the rear hub
I'm slowly getting into progress. I should learn a little more and to may print out something more serious :dance:
Old 03-19-2022, 09:54 PM   #22
quadzero
quadzero's Avatar
Wow, this is incredible and fun. Keep the great work.
quadzero is offline   Reply With Quote
Old 03-29-2022, 11:01 AM   #23
Serioga
Serioga's Avatar
Hello, Friends!
It's time to upgrade.
I have sanded trim lines in the draft version
Yes, I noticed that gutters run along the upper edges of the roof...
...decided to reproduce them. Cut "skis" out of brass
Something like this they could look like:
And here's the reason for the break: 5 or 6 times I glued the side panels. I was never able to glue them perfectly, and even squeeze a piece of brass between the roof and the sidewall ***
In general, "skiing" has been postponed for now. Then I'll stick it on...from Evergreen.
I took care of the front axle. The donor Ford has a narrower track than the GMC. Front axle*with rotary fists is about 64mm, and you need about 75.
I cut off the plastic axles from the differencial, replaced them with brass. It's harder.
Drilling the differential was difficult. One half inside is a pipe, but of a smaller diameter than necessary.
The rotary knuckles also had to be drilled to accept the brass pipe. First with drills, and then, at the edges, with an end mill. Yes, the reciprocal parts of the fists were also drilled and cut to accept the brakes. The right one hasn't been cut yet
I tried on the wheel on the cargo hub. There was a reason I start learning 3D. I have showed the result last time.
The front of the cabin lacks rigidity. Pasted sheet plastic for now
Only in the photo I saw that the front of the roof on the left is lower than on the right. I'll have to re-glue it again**
Enjoy watching!*
Old 11-29-2022, 01:50 PM   #24
Serioga
Serioga's Avatar
How d'you!
Front hub
I'm slowly getting into progress. I should learn a little more and to may print out something more serious* :dance:
Re-glued the front left upper corner. It became even.
It's time to make the fire wall.
I have finally found a picture of the most "stripped" front wall of a cab
Started from styrene:
Next - putty
The floor is made of "candy" plastic 1.5 mm
It will be further developed (however, like everything else)
Molded a plastic pad under the wipers. It's still an intermediate option.
And I tried on a long-prepared etching
__________________________________________________ __________
The working season is over and finally I can get in modeling, my precious!
I remembered that there is such a project where it's time to put something on wheels. I started with axels. Shortened both about 10 millimeters.
From knitting needles bought earlier, I cut the spindles. The rear one is longer. The rear hubs and brake discs will sit on it.
And the front ones are very short. Actually, only the hubs and disks fit on them. Here, by the way, is the proof.
The holes in the brake discs from Plamoz (and, accordingly, in the hubs) are about 2.3 mm, and there were no such spokes in the arsenal. It is obvious that the brakes with wheels will stagger
However, with the help of adhesive tape, you can glue anything! In this case - electrical tape. One layer was enough.
I made new steering rods. Ford's one were too large and in wrong place for GMC.
Finally - test fitting!
Enjoy watching! Feedback is welcome! :bye:
Old 11-30-2022, 08:24 AM   #25
Serioga
Serioga's Avatar
Greetings!
To catch up to yesterday: I soldered and put a steering link, and also made a blank cover over the clutch. It will also be necessary to process the edges .
The Following User Says Thank You to Serioga For This Useful Post:
mrgixxer (12-01-2022)
Old 12-01-2022, 04:24 AM   #26
Deathtrap
Ahhh very cool that you are continuing on this. Great scratch work in general.
Deathtrap is offline   Reply With Quote
Old 12-02-2022, 05:38 AM   #27
stratos75
Loser
stratos75's Avatar
Looks good on the wheels. Please, don't stop.
Best regards, Mikhail
stratos75 is offline   Reply With Quote
Old 12-11-2022, 10:36 AM   #28
Serioga
Serioga's Avatar
Hello, dear colleagues!
There is no progress on model itself, BUT the work from the workbench smoothly migrated to the computer. I tried my hand at a more complex element (for me) than the hubs
I did it according this photo:
Mikhail helped me to discover this one
That's what I got:
These stiffeners were my headache for some time.
Old 12-14-2022, 01:05 PM   #29
Rod666
Incredible work!
I hope, it won't be released right after you finished it!
Rod666 is offline   Reply With Quote
Old 12-17-2022, 10:50 AM   #30
stratos75
Loser
stratos75's Avatar
Originally Posted by Serioga View Post
PETERSON have made wheels for this project!
I think, nobody know here who is it.
Nice progress.
