Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-28-2019, 05:02 PM   #1
imakedacookies
Somethings funky 08 dodge rear end
On my 08 3500 cab and chassis dually I'm having some wierd issues that I just cant quite explain and am ready to catch the thing on fire. Long story short. In the last 40k miles I've gone through 5 rear seat of brake pads, 3 rear rotors, and a caliper, and countless calipers slide bolts sheared off clean in the mounting bracket. Shredded inner and outer bearing on one rear side also for some reason the axle on one side seems to push itself out enough to break the seal and strip a couple threads on each bolt and proceed to cry black tears down my wheel. (That last one happened today, it wasn't leaking on my way to work, moved it .5 miles to get a different piece of equipment and there was the oil) I've fixed everything as it happens and it always happens fast. Like within a 100 miles. I check everything on the rear end every morning because it's been such a issue and then something decides to shred itself. What the hell can cause such disfunction on a rear end? I drive almost nothing but dirt roads which is hard on a pickup but this is way too excessive and I don't drive it hard at all.
imakedacookies is offline   Reply With Quote
Old 10-29-2019, 07:18 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: Somethings funky 08 dodge rear end
Sometimes the brake hoses get clogged with rust and won't release the calipers when you lift the pedal and the brakes drag/continue applying/get stinking hot.
Is that what you're seeing?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 10-30-2019, 08:28 AM   #3
imakedacookies
No they don't stick or anything. When I did the caliper I flushed all the fluid to be sure it was clean. I talked to a dodge shop near here yesterday they think the rear end is the problem. They want to look at it but they think its bent or the axle is.
