Old 02-12-2004, 11:27 AM   #1
DCP
Primer question for all you paint pros....
Do you guys prime everything?
Yes I've read the FAQ, & yes I know primer is a must for the body to get good results.
But what about everything else: Do you prime the interior? The chasis?
What about the tiny parts? Won't the primer cover of fill in the detail?
Thanks in advance,
David
DCP is offline   Reply With Quote
Old 02-12-2004, 11:35 AM   #2
Vric
Vric's Avatar
Re: Primer question for all you paint pros....
no
I prime only the body, and sometime piece if I need to paint them bright red and it'S molded in black
else I only use paint
Vric is offline   Reply With Quote
Old 02-12-2004, 11:41 AM   #3
OzZySi
OzZySi's Avatar
Re: Re: Primer question for all you paint pros....
Originally Posted by Vric
no
Yup, I only prime the body, unless like vric said, you need to make a radical color change and you need a good base coat.
~OzZySi
"It's better to be a living dog than a dead lion"
OzZySi is offline   Reply With Quote
Old 02-12-2004, 12:45 PM   #4
dag65
dag65's Avatar
Send a message via Yahoo to dag65
I prime any parts I am using auto paints on including interiors and engine /chassis parts
dag65 is offline   Reply With Quote
Old 02-12-2004, 02:35 PM   #5
Veyron
Veyron's Avatar
It's a call you make from experience, knowing when you need to and when you don't. It is a variable in the building process, not a given like removing mold lines etc.
Veyron is offline   Reply With Quote
Old 02-12-2004, 03:31 PM   #6
ZoomZoomMX-5
ZoomZoomMX-5's Avatar
I rarely prime anything but the body. I prime the body primarily because it will have minor scuffs from sanding/polishing the mold lines out, and I want the final color to look it's best and that usually comes from a good smooth coat of primer first. However, since most of my interiors are airbrushed w/flat acrylics, they don't have the tendency to run or etch the plastic like lacquers, so even when I've done a lot of sanding on the seats (the mold lines are a bitch to remove but it's a necessary evil), the paint covers up the sanding marks...and I'm more careful to get these parts smooth. I'll prime a chassis if it's being shot in body color vs. just painting it in black.
My Fotki Album
ZoomZoomMX-5 is offline   Reply With Quote
Old 02-12-2004, 08:51 PM   #7
primera man
"P-Man"
primera man's Avatar
Just Prime The Body Only
View All My Models Here.
primera man is offline   Reply With Quote
Old 02-13-2004, 12:10 AM   #8
RallyRaider
Zomby Woof
RallyRaider's Avatar
Generally just the body. However, if a part has been modified in a major way then a coat of primer is useful to ensure everything is aligned and correct before painting. Basically I only primer when I absolutely have to, it takes too much extra time! For example, I'm doing a lot of cleanup and a few mods to the dash on the kit I'm building at the moment. When finished cutting, filling and sanding, I'll give it a coat of primer to ensure all is as it should be.
RallyRaider is offline   Reply With Quote
