Go Back   Automotive Forums .com Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 02-05-2008, 10:55 AM   #1
driftracer19
How many times can you stretch or shrink metal
Is there only a certan amount of times you can ctretch and shrink metal before it cant be done anymore? If so does it weaken the metal.
driftracer19 is offline   Reply With Quote
Old 02-08-2008, 09:24 AM   #2
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Send a message via MSN to Greenblurr93
Re: How many times can you stretch or shrink metal
Depending on the metal, you can work harden it. Ill use a paper clip for example.... unfold a paper clip... pretty easy right? now fold and unfold the same spot.... gets harder to do... that is because the metal is actually getting harder as you work it... eventually the paperclip will break because with strength... comes rigidity... and eventually brittle..
Greenblurr93 is offline   Reply With Quote
Old 02-09-2008, 05:00 PM   #3
CarBeater
Over working the metal will cause it to become too work hardened and tear on you. If this happens, the panel is probably in bad shapre, which may require replacing the part.
CarBeater is offline   Reply With Quote
Old 03-01-2008, 09:32 PM   #4
mopar=power
well when you see a tool that is tempered it has gone through heating then rapid cooling to strengthen it but to much will eventually crack the metal
mopar=power is offline   Reply With Quote
