12-21-2007, 05:26 PM | #1 | |
96 3.0L cooling issue
I am working on a 96 Ford Aerostar 3.0L, I have rpelaced the Water Pump, Heater Control Valve, Upper/Lower Radiator Hoses, Radiator, T-Start - all for different reasons.
Well now it just came back when it started overheating he (owner) checked coolant level in rad and was empty so he added water and brought it in so we could look at it. well the problem is that the coolant is flowing into the overflow bottle normally when it gets hot and pressure build up but is not returning to the radiator, so when it cools down and checked the radiator the level is low then when you fill it and let it warm up it does the same thing expands to the overflow bottle and does not return and it gets so full it pours out of the overflow bottle - so I replaced the Radiator Cap and Hose to the overflow bottle and still the same thing and that did not change a thing. Anyone have any ideas..... Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust). W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap. |
12-21-2007, 10:23 PM | #2 | |
Re: 96 3.0L cooling issue
anyone?
02-05-2008, 06:29 PM | #3 | |
Hi ,I have a Aerostar 97 and there's not enough heat when turn the heat on end the fan we changed both head gasket they were leaking from the outside, does the thermostat is supposed to be always open after the engine is hot? or does the rad. have to be replace cause maybe poor circulation?
07-30-2008, 03:35 PM | #4 | |
If only one radiator hose is hot the radiator is plugged or the thermostat is stuck closed. Put a pressure tester on the radiator if the gage pulses when running you have a blown head gasket. Try to borrow a pressure tester from Advanced ,Auto Zone or O'Riley's. They have a tool loaner program.
