Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Old 03-28-2010, 11:22 PM   #211
boostjunkie333
boostjunkie333's Avatar
Send a message via AIM to boostjunkie333
Re: Junkies 97 RS Rebuild(1st timer!)
Ok. When I get out in the garage working on it again ill see which ones i do have.
Hey, the rods that were ok, do they need to be re conditioned at the shop or would they be ok?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
boostjunkie333 is offline   Reply With Quote
Old 03-29-2010, 07:17 AM   #212
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
The good rods are fine. Just put them back in with the new bearings
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 03-29-2010, 09:58 AM   #213
boostjunkie333
Ok. Good deal
Old 03-29-2010, 09:46 PM   #214
boostjunkie333
Ok, pistons, there is like a little ring that holds the wrist pins in on each side, just want to make positive, i pop these off and use a socket to knock the wrist pin out?
Old 03-29-2010, 10:48 PM   #215
david-b
Dave is THAT guy
david-b's Avatar
That will work. Don't lose or damage the pin though. And remember the direction that they came out. The pistons have to be connected to the rod and to the crank the same way. I forget the name of why, but I believe it has to do with the rotation, keeps everything from falling out/apart.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
david-b is offline   Reply With Quote
Old 03-29-2010, 11:01 PM   #216
boostjunkie333
ok.
Old 03-30-2010, 04:04 PM   #217
boostjunkie333
Hey does anyone know if eagle does core returns? Or should I just keep these rods as paperweights?
Old 03-30-2010, 06:42 PM   #218
SilvrEclipse
Holset powered 420a
I doubt they do, never heard of anyone returning any. I like to keep broken parts displayed on the mantel. Problem now is i am running out of space bc i have so many broken parts
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 03-30-2010, 07:06 PM   #219
boostjunkie333
Good idea
Old 03-30-2010, 11:33 PM   #220
boostjunkie333
Here how clean I was able to get the pistons...
Old 03-30-2010, 11:38 PM   #221
boostjunkie333
Old 03-31-2010, 10:26 AM   #222
boostjunkie333
I cant seem to find the same rods as mine...like the ones I look at on ebay, dont quite look like mine...or maybe they do and I just can't tell. Does eagle only make ONE kind of rod for the 420a?
Old 03-31-2010, 11:18 AM   #223
david-b
Dave is THAT guy
david-b's Avatar
http://www.eaglerod.com/
There should be a part number on the rod etched in. Look up and compare
75 Monte Carlo
Old 03-31-2010, 02:42 PM   #224
boostjunkie333
ok, gotcha
Old 04-02-2010, 02:04 PM   #225
boostjunkie333
Hey, I scrubed the pistons clean, except for a teeny bit of discoloring on the underside of the pistons that I cant really get to good enough, but just in the corners, its clean as hell though. Theres somehting that stands out to me and I wanted to make sure, on the piston skirts, there is no damage, no nicks or gauges or anything physically wrong with them at all, but on like 2 of them there is like a discoloration...like wear i guess...is this bad? or normal?
