Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Members Projects
Members Projects Discussion of the AF 2G DSM Project Car
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 12-28-2009, 05:39 PM   #106
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
Got kind of an important question. I found out why my turbo timer stopped working, the wire was pinched between the ecu and mounting bracket. So it was cut damn near all the way through. My concern is with the wires being as fine as they are, is it ok to just reconnect them? I tried soldering them but I guess I'm really bad at soldering and I was having difficulty getting the solder to stick to the wire. So I just got a little bit of solder on them then I used shrink wrap and then taped them all together. There's this tin foil like material that surrounds the wire that I just kind of rewrapped the foil and called her good. Would everyone agree that this is safe or is there something else I should do?
ned032002 is offline
Old 12-28-2009, 06:18 PM   #107
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Re: Ned's 91 GSX
It should be fine as long as the wires have a good connection. Does the TT work now?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline
Old 12-28-2009, 06:25 PM   #108
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
I don't have the battery hooked up right now but I plan to hook it up to make sure the fuel pump works so I can test that too.
Edit: hooked up the battery, turbo timer works but the fuel pump doesn't come on. I tested the wires and the wire I cut and tapped into are showing no current using the multimeter. I lost the cover to the fuse box cover so I can't see which fuse controls the pump. Or how it could have blown I have no idea. Confused here, any suggestions.
Old 12-29-2009, 07:46 PM   #109
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
Recharged the battery cause it was only showing 8.5v so charged it up and retested wires. Again...no voltage through that wire. I even tried further up the wire and again nothing. Can't find where the problem is. I even reconnected the 2 back together and still nothing. I don't see what the problem could be.
If I connect the 12V lead wire to the black and white wire, that will at least test the pump but won't solve the problem. My question there is, will this harm the pump if I do that just to test it?
Is there a fuse or relay that I should check? I did the vacuum removal so does that pump work on vacuum in anyway that may have been effected? I left only the lines that the vfaq said to leave. This is a stupid problem but a serious one at that.
Old 12-29-2009, 09:58 PM   #110
SilvrEclipse
Holset powered 420a
Re: Ned's 91 GSX
It wont hurt the pump to connect it directly to the battery. You only want the pump to run when the motor is running tho. You could run a power wire to the pump and put a relay in there. Just like you are rewiring it if you cant figure it out. It is probably a fuse.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-29-2009, 10:15 PM   #111
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
What could have caused the fuse to blow? I know that's a stupid question but I didn't short anything out to my knowledge to have blown anything. Isn't the pump suppose to come on whenever you first turn on the key? I guess I can pull the fuel line off the fuel rail and see if fuel was pumped to that point. I don't know what else to do here.
I guess the starting question is: Is the pump suppose to come on everytime when you first turn on the key?
Old 12-30-2009, 01:19 AM   #112
SilvrEclipse
Holset powered 420a
Re: Ned's 91 GSX
I think it depends on the car. I know all 2gs prime when you turn the key but I have heard that some 1gens did not prime. There should be no reason not to have power at the pump if the fuse is not blown. Unless the ECU is killing power to it for some reason. I would check every fuse under the hood and under the dash. You need to see if it gets power when cranking tho. If it doesn't then you may want to check to see if the injectors have power or not. On the 420a ECU the power for the fuel pump, injectors, coil is all tied together so if one doesn't have power neither does anything else.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-30-2009, 06:50 AM   #113
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
When I get out of work tonight, I will check the fuses. Hopefully it's something easy like that. I can't crank the car yet, so that will have to wait a little longer.
Old 12-30-2009, 08:48 AM   #114
david-b
Dave is THAT guy
david-b's Avatar
Re: Ned's 91 GSX
Isn't there a relay too for the fuel pump? Could that maybe be blown?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
david-b is offline
Old 12-30-2009, 09:52 AM   #115
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
I couldn't find a relay that said "fuel pump" so didn't get any further there. I looked through the chiltons manual, looked through the wiring diagrams and got nowhere.
Old 12-30-2009, 10:18 AM   #116
vanilla gorilla
vanilla gorilla's Avatar
Re: Ned's 91 GSX
I know on 2g's the fuel pump relay is under the dash right beside the ECU, on the passenger side.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
vanilla gorilla is offline
Old 12-30-2009, 10:51 AM   #117
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
When I get home I'll have more time to mess with it.
Old 01-01-2010, 07:34 PM   #118
ned032002
ned032002's Avatar
Re: Ned's 91 GSX
Well none of the fuses are popped. Someone suggested that I just turn the car over a couple turns to see if the pump turns on or not. I don't have any oil or coolant in the engine so it's probably not a good idea to do this right? The radiator hoses aren't installed either. Suggestions?
Old 01-01-2010, 11:34 PM   #119
vanilla gorilla
Re: Ned's 91 GSX
It wont hurt to run the car for a short period of time with no coolant, but I wouldn't turn it over without any oil in it.
Caleb
vanilla gorilla
Old 01-02-2010, 08:19 AM   #120
david-b
Dave is THAT guy
david-b's Avatar
Re: Ned's 91 GSX
Oil is needed for sure. And since there's no oil, make sure you crank it with the coil pack unplugged a couple times to prime the motor before you actually try starting it.
75 Monte Carlo
david-b is offline
Closed Thread
