| Latest | 0 Rplys |
12-06-2007, 09:51 AM | #1 | |
4WD Wont Disengage
Well its that winter season now and i just used my 4wd because we had our first snow of the season here in md and of course the roads turned to ice. So i pull out my neighborhood and get to the main road where i wont need 4wd. I flip the button to dissengage and the 4wd and i drive about 4 to 5 miles and the damn thing just keeps blinking..Ive checked Iz FAQ searched the forum but havent found anything to do with not disengaging. Any ideas?
Thanks Danny |
12-06-2007, 04:27 PM | #2 | |
Re: 4WD Wont Disengage
What vehicle?
If a Rodeo you could first check for vacuum leaks around the vacuum tank and hoses (near the oil filter). '99
99 Holden Frontera SE (Isuzu Rodeo) 3.2 V6 DOHC Victoria, Australia. |
12-07-2007, 07:26 PM | #3 | |
Never heard of one not comming out ouf 4wd before. Could be the actuator is stuck, could be the 2wd vacuum hose came off, or could be a bad vss switch. To get it back into 2wd for now you could try putting it in 4wd then swap the hoses on the front actuator. That should pull it back to 2wd position. Once its moved, remove the hoses, put it in 2wd, the reconnect the hoses to the right spots. Here is a pic of the front actuator with the hoses marked..
Check THIS POST for tips on troubleshooting the system.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
12-08-2007, 12:19 AM | #4 | |
my 01 passport did the same thing the first couple of times i used it. It would flash rapidly after taking it out of 4wd. I just stopped and backed up and it disengaged. It did it a couple of more times but has stopped now. I have heard you should put it in 4wd a few times a month to keep the actuator working properly.
12-10-2007, 10:59 AM | #5 | |
Finally got it to come out, i was at the store and backed out of my parking spot and it disengaged. Thanks for the help guys
