| Latest | 0 Rplys |
02-06-2005, 10:10 AM | #46 | |
Re: 4 headlight mod
the high beams in a 1999 - 2002 are one ofthe few things that switch on the positive wire with out a relay ..... i would put a relay in so the fog lights would come on with your high beams
02-07-2005, 12:35 PM | #47 | |
Re: 4 headlight mod
Silveradoking...the 100.00 is to tell the computer that fog lights are installed. All plugged in with all factory wiring and switch nothing happens when you turn them on.
04-16-2005, 10:51 PM | #48 | ||
Re: Re: 4 headlight mod
04-17-2005, 12:18 PM | #49 | |
Re: 4 headlight mod
Chuck, Firehawk, Walbern, or anyone else who has tapped the ground, what gauge is the "yellow wire?" I'm about to do the mod, but I want to make sure I get the right gauge tap.
04-17-2005, 02:01 PM | #50 | |
Re: 4 headlight mod
its a 16 guage i beleive, but lemme tell you right now dont waste the time with the relay, just tap into that yellow wire and ground it good, by far the best mod yet, ive done...took all of 5 minutes
'99 Silverado 4 x 4 bunch of goodies |
04-17-2005, 02:19 PM | #51 | ||
04-22-2005, 02:19 PM | #52 | |
Re: 4 headlight mod
Does anyone know how to do this on a 99 Tahoe?
The circuit panel looks different and the relay described is for the horn, and there are no yellow wires. |
04-22-2005, 03:03 PM | #53 | ||
09-01-2005, 07:24 AM | #54 | |
I want to do this mod this weekend. Before I start tapping wires, I want to verify the correct yellow wire.
I am assuming it is the yellow wire in the upper right corner on the grey-white block. Someone please confirm. Marmot |
09-01-2005, 08:55 AM | #55 | |
Re: 4 headlight mod
Yes, simple and cheap. That is the correct yellow.
"The Sleeper" '05 6.0L VHO Cam in and Low 14's happening at the track Check out my Ride |
09-01-2005, 04:34 PM | #56 | |
Re: 4 headlight mod
Yeah I tapped mine with yellow wire and tucked it into some conduit on the way to the grounding nut/stud... barely noticeable untill I get behind you and blind your ass!
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
09-01-2005, 04:40 PM | #57 | |
Re: 4 headlight mod
I wonder if the 2005/6 models will offer this feature. It seems silly to me to not have this as a standard feature. For something so easy it should be standard. Such a great mod....
2008 GMC ACADIA SLE Edition, 7 passenger model I AM Canadian!! |
09-01-2005, 04:44 PM | #58 | |
Re: 4 headlight mod
Hey, Chuck, what did you have to do to keep your fogs on with your high beams?
09-01-2005, 07:34 PM | #59 | |
Re: 4 headlight mod
My '05 does not stay in the 4 light mode. If you pull it for passing it will go to all on but pops off when you let go. I beleive the '04 and up is the reverse polarity switched and thus takes different wiring to make it happen.
09-01-2005, 10:51 PM | #60 | ||
I was sadly disappointed that they don't throw a lot of light. I had Bosch Pilot Driving lights on my last vehicle and I miss them. I can't wait for these to burn out or somebody who wants them cause I'm ready to chuck'em. Think I'll go with some Piaa's or something like that... Hope that helps.
