11-25-2011, 06:19 PM | #1 | |
In the 200 Club
1993 TransSport Transmission Fluid Leak
Tranny fluid spews out pretty good underneath. Is it likely a broken hose? Where do I start?
11-25-2011, 08:42 PM | #2 | |
Re: 1993 TransSport Transmission Fluid Leak
Could it be a broken/rusted transmission cooling line? Sure....
Could also be a pan gasket, damaged pan, axle seal, filler tube seal, side cover gasket, etc. You will have to find the source of the leak... |
11-25-2011, 09:32 PM | #3 | |
In the 200 Club
I will have to get it up on blocks so I can climb under there to see and feel I guess.
11-26-2011, 12:02 AM | #4 | |
Transmission lines leading to the front cooler are indeed the likely suspect. Mine are now routed to a separate transmission cooler using rubber lines. I had problems with the power steering fluid lines running to the front crossframe too (acting as a contact cooler ).
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
