Go Back   Automotive Forums .com Car Chat > GMC > Yukon
Old 02-14-2004, 01:25 PM   #1
denjandav
97 gmc yukon misfires at speeds over 50
Does anyone know what might be causing a misfire on my 5.7l v8. I have change the plugs, wires, dist cap and ignition module but mis continues. The miss starts at steady speeds over 50 mph. If I speed up miss goes away but when my speed is steady again it begins missing again.
Any ideas
denjandav is offline   Reply With Quote
Old 02-22-2004, 01:19 AM   #2
surfing
Hmmmmm.....did you gap the plugs to specs?? IF so, then you may need to pull'um out, and make sure none are fouled, wires are correctly seeted, ect.. .
surfing is offline   Reply With Quote
Old 04-24-2004, 08:58 AM   #3
usscvr
Send a message via AIM to usscvr Send a message via MSN to usscvr
Re: 97 gmc yukon misfires at speeds over 50
Wow! I have the same problem, although my has gotten worse with added mileage. Check out my post from USSCVR, "SES Lamp Multiple Engine Misfire." Are we having the same problem here? Have you isolated it yet?
usscvr is offline   Reply With Quote
Old 06-22-2004, 09:24 PM   #4
snr8715
Fuel injector
snr8715 is offline   Reply With Quote
Old 06-23-2004, 09:11 AM   #5
usscvr
Wow! Glad you found your problem.... but I have throttle body injection on a 5.7 350; no fuel rails, no individual injectors - UGH! Still a problem for me... Any suggestions?
Old 10-22-2004, 08:45 PM   #6
Suburbman
Did you finally find out what the problem was with the '97 350 misfire at speeds above 50? Was it an injector. I'm having the exact same problem, no misfire codes either.
Suburbman is offline   Reply With Quote
Old 10-23-2004, 12:49 PM   #7
usscvr
No, I haven't.... ugh! I do not have individual injectors. My Yukon has a throttle body injector system, thus no fuel rails, no individual injectors, etc. I am still at a loss. Any suggestions????
Old 10-25-2004, 08:48 AM   #8
tscholz
How many miles on the odometer? I have seen ditributor shaft bushing worn to the point that the engine will misfire at times.
tscholz is offline   Reply With Quote
Old 10-25-2004, 11:22 AM   #9
usscvr
It stared at around 65-70K miles. I now have 120K, and nothing has changed, no better, no worse. Honestly, I haven't done much since spending thousands on it the first few times. It appears to be more of an annoyance than anything. We've gotten used to it ~ that's not to say that what's happening is good for the vehicle; I know its not. But, we've learned to adjust our driving habits accordingly. We (my wife) loves the Yukon a lot, otherwise, or I would have gotten rid of it a long time ago.... LOL! What Ms. Honey wants, Ms. Honey gets....
Old 11-14-2004, 10:55 PM   #10
lodownlv
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
you have a faulty fuel injector.. no doubt about it try running some lucas fuel injector cleaner along with spraying some carb cleaner directly into the throtle body at high rpm's then make sure u have acdelco spark plugs properly gaped at .006
lodownlv is offline   Reply With Quote
Old 04-09-2005, 09:22 PM   #11
crazy202022
check egr valve.
crazy202022 is offline   Reply With Quote
Old 04-09-2005, 09:57 PM   #12
usscvr
Originally Posted by crazy202022
check egr valve.
Really? EGR? I didn't think about that. Well, I figured it was a sensor somewhere, but the EGR didn't cross my mind.
Can you tell me any quick checks for this? Or is this a dealer check?
Old 04-09-2005, 10:25 PM   #13
2000CAYukon
Re: Re: 97 gmc yukon misfires at speeds over 50
The EGR valve is subject to a lot of heat and they do wear out. With your mileage, I would just replace it and make sure the passage inside the intake is not clogged (when you remove the old one you can see how it looks). Some people recommend replacing the egr solenoid at the same time.
//2000CAYukon
2000CAYukon is offline   Reply With Quote
Old 04-10-2005, 06:31 AM   #14
lodownlv
the egr valve wouldnt do it and if it was sticking it would throw the SES lite. whoever has this problem start with the fuel injection system bad injector or fuel pressure regulator would cause loop at high rpms and rough idle. i can assure you that its not the egr
Old 04-10-2005, 10:49 AM   #15
usscvr
OK, if you read back in the post, you'll see that I have a throttle body fuel injection system, not individual injectors ~ so a 'bad injector' can be ruled out. However, the Fuel Pressure Regulator makes sense. Where is it located? How can I test it?
With the number of miles, changing the EGR might make sense, too. But fuel delivery has always been my concern. Where is the F.P. Regulator? Is it available aftermarket?
