Go Back   Automotive Forums .com Car Chat > Cars in General
Old 09-17-2004, 02:34 PM   #1
"Papa" Pfohl
Unhappy clear coat came out bad.
I have not shot a car in years. Tried to help my son>>>>>not good.
he wet sanded nicely. shot 3coats of GMC Black. (did not wet sand again) shot with 4 coats clear and the clear came out very spotty. dull in some areas gritty in others and perfect in others. Can we wet sand again? I'm gussing with 600 grit and re shoot. By the way we used the same gun for paint & clear at 35psi
Thanks
Papa
"Papa" Pfohl is offline   Reply With Quote
Old 09-17-2004, 04:03 PM   #2
mike@af
Captain Over Engineer
mike@af's Avatar
Re: clear coat came out bad.
Try wetsanding the rough area's out, and then reshoot the whole thing again. If that comes out pretty nice, wetsand with 2000.
-Mike
mike.lawrence@automotiveforums.com | AutomotiveForums.com | Flickr Gallery
mike@af is offline   Reply With Quote
Old 09-19-2004, 01:30 AM   #3
Markgase2000
Markgase2000's Avatar
Send a message via Yahoo to Markgase2000
You may also have an adhesion problem.I know some tricks if the spots your refering too are fish eyes or major orange peel. Also you used the same gun for both processes so what type of paint is your base and what type is the clear? I also have tricks for using different types of paint together and force curing methods that help. BTW I wish my dad had the same enthusiasm with auto stuff cus it woulda been funer to do things like that.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Markgase2000 is offline   Reply With Quote
Old 09-20-2004, 08:44 AM   #4
CpaintCars
Sounds like you drysprayed....one of these things happened:
1) You sprayed from too far away so the paint dried before it hit the car
2) You sprayed too quickly, not allowing enough paint to accumulate and lay out flat like glass.
3) It was too hot when you sprayed or you sprayed in direct sunlight
These are the most common reasons for getting a textured/dull finish to your paint job.
If you need more help or step by step instructions call 1-800-548-4321, very knowlegeable, friendly, and I've used them for years.
CpaintCars is offline   Reply With Quote
Old 09-20-2004, 08:58 AM   #5
Markgase2000
Wish I thought of that , same thing happened to me a year ago on some trim with enamel paint. It was like dust falling off the trim lol thanks for the number cap
