| Latest | 0 Rplys |
01-02-2005, 11:27 AM | #16 | |
Re: 95 k1500 350 tbi stalls
Almost forgot the wires at the fuel pump are known to get all green and gunky and that cause high resistence in the wires . it causes the fuel pumps to heat up the shut down so check the wires at the tanks real close and clean any that look discolored
01-02-2005, 04:22 PM | #17 | |
I did look over my pump/tank wiring when I had the box off to replace my pump, with nothing evident. I do notice that my voltmeter jumps up/down with the electric load varing, ie; signal lite flashing. It has been doing this since I had the truck (3-4 yrs). Spoke to other owners of these & theirs stays steady. A bad/corroded connection - related to this or not????. I will check out the wiring around the TBI/ injectors & try the "tap test" on the ECM
01-02-2005, 04:25 PM | #18 | |
chaynes, was that the pump voltage you were checking ,or the injector volts???
02-03-2005, 03:57 PM | #19 | |
It turns out that the ignition control module was bad. It also
will shut the fuel off so that it will not keep sending gas into the engine. |
02-03-2005, 04:00 PM | #20 | |
Any idea on what automatic transmission they put in a 1993
k2500 pickup with a 6.5 diesel engine. I have a manuel now and I would like to switch to an automatic |
02-09-2005, 11:19 AM | #21 | |
Not too sure about that one. We had a 1990 3500 6.2L diesel at work (old body style) & I seemed to think it had a 4L80e. I tried the module in my truck, but it didn't fix it. The last thing I tried was a bottle of injector cleaner ,which was back during Christmas & it hasn't acted up since. I suspect this must have cleaned some gunk out of the fuel press regulator.....
02-18-2005, 10:24 AM | #22 | |
I have a similiar problem on my mudder but not as extreme, I have changed the FPR, Entire distributor, Fuel pump, filter & TPS. Now it will run fine but stall once in while at idle, It's annoying and you'll feel a surge to try to stay on but dies under load, Haven't had a chance to drop it off at a buddys shop, I will post what he finds out once it's there. It's getting old I'm ready to swap out the ECU since I get no trouble codes and it still passes smog?
There is no substitution for horsepower, bigger tires and more lift! [img] |
