Go Back   Automotive Forums .com Car Chat > Lincoln > LS | MKZ
Old 09-20-2010, 06:24 PM   #121
masterlocke405
Re: codes P0171, P0174 Lincoln LS V6"
Hi, I am new to the forum. I am having the same troubles as what much has been described here. I have a 2001 LS V6 auto and my code reader is giving me P0171 and P0174 also. I have cleaned the MAF sensor up and would like to try the PCV valve next. I am looking for some instruction and pictures if possible.
Rod, PM sent.
Thanks!
masterlocke405 is offline   Reply With Quote
Old 09-22-2010, 06:34 AM   #122
shorod
SHO No Mo
shorod's Avatar
Originally Posted by masterlocke405 View Post
Rod, PM sent.
E-mail sent.
-Rod
shorod is online now   Reply With Quote
Old 10-15-2010, 10:55 AM   #123
mamee
Hi I have codes P0171, P0174 Lincoln LS V6. Waht is the best way to fix this problem? Please advise
mamee is offline   Reply With Quote
Old 10-15-2010, 10:56 PM   #124
shorod
SHO No Mo
shorod's Avatar
Welcome to the forum!
Did you read the posts in this thread?
-Rod
Old 10-15-2010, 11:16 PM   #125
danielsatur
This problem was resolved 7-years ago, please use search tools, and similar threads in forum.
I put a ACME AUTO EMISSIONS FILTER, on my Jaguar, so the emission gunk wouldn't contaminate my MAF, IACT, H02 sensors, Throttle body, and catalytic converters.
The filter seems to squeeze oil out of the emissions, before going back into the intake of motor.
Contaminated sensors seem to give the wrong signals to the Engine control unit and leads up to throwing Diagnostic Trouble Codes( DTC) , because of bad, or dirty sensors.
See http://www.ideabuyer.com/ipavail/acm...issions-filter
danielsatur is offline   Reply With Quote
Old 10-16-2010, 08:36 AM   #126
pj96ss
Hi All,
I just picked up a 2000 LS with 35,500 miles last week and it just threw codes P0171 and P0174. Looks like they all have issues.
Rod, I sent you a PM. Can you send me the info that you've sent others.
Thanks,
P.J.
pj96ss is offline   Reply With Quote
Old 10-16-2010, 08:41 AM   #127
shorod
SHO No Mo
shorod's Avatar
The files should be in your inbox shortly.
-Rod
Old 10-25-2010, 11:26 AM   #128
pj96ss
My pcv elbow was collapsed with a hole in it. A new pcv and elbow, new gaskets, and spark plugs and she's running great (knock on wood).
P.J.
Old 10-25-2010, 01:36 PM   #129
shorod
SHO No Mo
shorod's Avatar
Congrats, and thank you for the follow-up!
-Rod
Old 11-08-2010, 08:39 AM   #130
Pelikans
Rod, thanks for providing this. Please send to donotusethispart-Pelikans@charter.net.
Pelikans is offline   Reply With Quote
Old 11-11-2010, 11:19 AM   #131
ab1234
my 2000 ls randomly shuts off at idle too though most people here have done the work themselves and I understand the cost of taking it in was eliminated. I'm curious as to the cost of the elbows, gaskets ect. to personally complete the repair our engine hasn't been taken care of too well and is the only family car we bought it used and have had nothing but problems with everything from windows to this now I was going to take it in for an oil change and ask the machanic his price but I'd like to know what you guys spent on the project my husband may be able to repair it himself if this is indeed the problem I need to at least make the car last the next few years and be reliable. thanks any info in this case would be great!
ab1234 is offline   Reply With Quote
Old 11-11-2010, 12:41 PM   #132
shorod
SHO No Mo
shorod's Avatar
I don't know what a shop would charge for this, but keep in mind that there are not a lot of these cars on the road, and the engine was pretty much specific to this model (as well as a Jaguar, also not high production). There won't be a lot of shops that will know what needs to happen. They will however have labor manuals that they will base their estimate off of. The PCV elbow runs about $25 from the dealer. Anticipate about a 40% markup if you are paying a shop for the work, plus probably 2 hours for labor at $100 per hour (rough estimate). If you opt to have the plugs changed while they're in there (recommended) then you might expect to pay another $10 per plug x 6 plugs. The added labor may be another 30 minutes if they are doing the PCV elbow anyway. If they find that the valve cover gaskets are leaking, then you're probably looking at another $120 for gaskets and shop supplies and maybe another 1 hour for labor. They'd probably want to replace one or more coils which may run another $150 each and really no extra labor since they'd need to come out to change plugs and/or valve cover gaskets.
For your stalling though you might first want to start be checking the age of the battery in the spare tire well. If it's 3 or more years old, you might change it and see if that fixes some of the issues. The electrical system in these cars is quite sensitive.
-Rod
Old 11-15-2010, 12:48 AM   #133
xlu
Hi Rod, can you email me the instructions to replace the PCV elbow please?
BTW, how to send my email address to you in private?
Thanks
xlu is offline   Reply With Quote
Old 11-15-2010, 06:32 AM   #134
shorod
SHO No Mo
shorod's Avatar
Left mouse click on my username in a post chunk above (left side of the post), select "Send a private message to shorod".
-Rod
Old 12-03-2010, 02:42 AM   #135
CHAZ LS
Hey Rod, new member, same story here. 2000 LS V6 CODES P0171 P0174. Sent you a PM.. need those pdf's please. Thank you very much for your help.
CHAZ LS is offline   Reply With Quote
