05-05-2007, 11:36 AM | #1 | |
1987 Trooper II No fan and no turn signals
Hey guys and gals,
This is my first time posting here and this is my first Trooper. I bought an 87 Trooper in fairly good condition for $800.00. It has 204,322 miles but runs great, my only 2 problems that I have is that the turn signals to not function, no blink, no nothing. I have checked the fuse and it is good. Also, the fan for the vent/heat/ac does not come on. Any suggestions would be helpful. |
05-06-2007, 01:14 AM | #2 | |
Re: 1987 Trooper II No fan and no turn signals
Alright, I fixed the turn signals. It was a loose connection at the flasher. So now I'm just stumped on the blower.
05-07-2007, 07:11 AM | #3 | |
Have you checked for proper voltage output from the alternator? I assume you found fuse for HVAC system and it is good, If you are sure you are getting 13.6 V or thereabouts, then check for power at blower motor. If power there, then bad blower motor (check ground). You will just have to backtrack and this diagram may help. Good luck.
Heating and Air Conditioning
1994 Trooper SE w/ 3.2 DOHC Auto 2003 Olds Bravada |
05-07-2007, 09:51 PM | #4 | |
Thanks Mike,
Well tonight I figured out the problem with the fan. It seems there is a blower relay behind the driverside headlight, it has a rubber boot over it. I took this out and cleaned the connectors. I put it back in and now the blower works! |
