10-23-2004, 05:43 PM | #1 | |
air suspension
Can someone help? My suspension is sitting down in the back and I just replaced the relay. It's clicking in the back but the compressor won't come on, is there a heavy duty fuse to check first(I don't have an owner's manual) or am i resigned to the fact that the compressor is shot?
10-25-2004, 10:54 AM | #2 | |
Re: air suspension
I would say for than likely the compressor is shot. However, if you want to check the fuses for it first that's smart. Check the A fuse. The A fuse controls the power to the air suspension on your vehicle. If you need any more help just PM me and I will help out as much as I can.
11-07-2004, 10:17 PM | #3 | |
I had the same problem. If you use a circuit tester, is there a signal coming from the computer to the selenoid? That is what was happening with mine. Once I replaced the height sensor in the rear, everything was good. I have a wireing scematic that I can send you if you are interested.
