| Latest | 0 Rplys |
08-19-2004, 08:27 PM | #16 | |
Don't unhook the fuse in the lower right corner, if you do you'll need to input your radio code (if you know it it's obviously not a problem).
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
08-19-2004, 08:32 PM | #17 | |
ya, you shouldn't need to unhook a fuse to see if its good or not. Just get a simple current/fuse tester (about 5 bucks at any auto shop). Ground the clamp, then touch the tip of the tester to each terminal on the fuse. The fuse is good if either both terminals light up, or both terminals don't light up. The fuse is bad is one terminal lights up and the other one doesn't light up.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
08-20-2004, 09:27 AM | #18 | |
Re: Brake light stays on....
Brake fluid. ASAP.
Kris 2012 Genesis Coupe 2.0t |
08-20-2004, 12:00 PM | #19 | |
blue + red light magnet
If you are talking about the red light that says "Brake" in the middle of your dashboard next to the spedometer. Then the most likely cause is low brake fluid.
If you are talking about an actual brake light on the back of your car is staying on, then you need to check the wiring and fuses. But honestly, just check your brake fluid...it takes 2 seconds and is the most likely cause
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
08-20-2004, 03:05 PM | #20 | |
the brake fluid was full and the ebrake was real lose. The light didnt turn off untill i drove the car to the front of my house and then unscrewed the brake fluid cap. i dont know if the driving the car that far did it or unscrewing the brake fluid cap did it but the light is no longer on so im happy.
08-20-2004, 03:07 PM | #21 | |
If you have a rubber diaphragm under the cap, make sure it is tucked into the cap.
